2003 All Other Makes Repair Question
Asked on October 10, 2006
2003 MPV vibration in steering wheel at higher speeds
2003 MPV with 53,000 miles. Since we bought it a year ago, we've put up with front-end vibration at 60mph or higher. The faster we go, the more noticeable the vibration.
Also, when braking, there's vibration, which is the rotors needing to be shaved... but the dealer did that twice.
Is there something that may have caused both issues that I should check for? Tie rod? CV joint? Bushings?
Will try rotating tires front to back to see if vibration follows. Anything else you recommend?
