Mechanics
AIR BLOWING OUT OF THROTTLE BODY
1993 Toyota Camry • 225,000 miles
On a 93 Camry the main belt broke not the power steering belt so I put on a new surp belt and now the car will not start when cranking over it sounds different sounds kind of slow with a odd sound when cranking as I found is the odd sound is air getting pushed out of throttle body its not sucking in I have spark put in new plugs also the plugs were wet when I took them out. What is the cause of air going out of throttle body and not getting sucked in. This is my first time using this site if its something I like I will add donations in the future . Anyhelp will be good thanks BILL
Turbo1987
June 20, 2013.
As a rule, belts don't break on their own. It is usually triggered by one of the components it operates freezing up. I would remove the belt and make sure you can spin each pulley smoothly by hand.
Wrenchtech
Jun 20, 2013.
What would cause the air blowing out of throttle body and not being sucked in like it should. When cranking the motor
Turbo1987
Jun 20, 2013.
I have no idea what you are talking about there. There will be no air movement at cranking RPM.
Wrenchtech
Jun 21, 2013.
When I removed the air cleaner hose right at the throttle body I had someone crank it over to feel if it was pulling air in a little but when I put my hand over the throttle body opening and we tried to crank the motor it was blowing some air out so I sprayed throttle body cleaner in to see what it would do and it pushed it out did not suck in.
AD
Turbo1987
Jun 21, 2013.
AD
