Mechanics
ADDING GAS AT THE GAS STATION
2003 Ford Ranger • 3.0L V6 2WD Automatic • 200,000 miles
When you are adding gas to the truck the gas pump keeps shutting off a few cents at a time?
Thank you for your time hope to hear back soon
sincerely, Jim r
Baby grl
March 3, 2014.
Ok, does it do it at every station you stop at or every pump you use? If does it no matter where you fill up, the most likely cause is a clogged/blocked fuel vent line. If you notice when your filling there's a hole to one side or even at the top inside were you put the nozzle. That hose vents the tank so when filling it does not keep shutting off. To fix the problem you will need to remove the vent hose and either replace it or clear it out.
Obxautomedic
Mar 3, 2014.
AD
