1993 Acura Vigor Repair Question
Topics covered: Battery, Fuse, Circuit test.
Asked on May 30, 2010
1993 Acura Vigor Passenger side dim high / low
Electrical problem
1993 Acura Vigor Two Wheel Drive Automatic 150,00 miles
Tools used so far:
Digital Multimeter
Circuit Tester (red light = positive, green light = negative)
CAR OFF
What is throwing me for a loop is car off jumper wires to passenger low beam it is still dim. Driver and Passenger low beam harness (connector) I get 11.84v
CAR ON
Driver and Passenger low beam harness (connector) I get little above 14v and matches 14v a quick battery check between terminals. Swapped Driver and Passenger low beam bulbs between each other, whichever I put in Passenger side is dim. Fuse swap (20 grade) between Driver and Passenger fuses makes no difference so I do not believe it is a hairline crack in fuse.
Circling back, all this troubleshooting makes me keep wondering why Car Off battery to Driver side is normal brightness, battery to Passenger side is dim. I checked the mirror inside the passenger headlight and I do see a hairline crack near the bottom horizontally, BUT the Passenger High beam is dimmer then Drivers as well so I do not think it is the mirror casing.
Tools used so far:
Digital Multimeter
CAR OFF
CAR ON
