1992 Acura Vigor Repair Question
Topics covered: Engine, Mechanic, Timing belt.
Asked on February 4, 2010
1992 Acura Vigor Timing belt replacement
Engine Mechanical problem
1992 Acura Vigor 6 cyl Front Wheel Drive Automatic 187000 miles
Hi All, I am new here. I would like to replace the timing belt in my Acura Vigor. Before I start to take things apart, I have 2 questions, and I hope someone can help me here.
1) When remove the bolt on the main pulley, Do I turn the bolt in the "direction of rotation" to remove it, or the opposition direction.
2) When the bolt is remove, do I have the remove the key on the main shaft before I remove the main pulley, or there is no key for the main pulley.
Thank you in advance.
Xintol
Xintol
