1992 Acura Vigor Repair Question
Asked on April 18, 2009
1992 Acura Vigor Check Engine Light
Computer problem
1992 Acura Vigor Front Wheel Drive Manual 150000 miles
I know all the steps to get the light to start flashing the codes!! BUT,here is the problem,when I turn the key on all the light dose is one long flash after another!! It will Flash one long flash shut off for 2-3 sec. one long flash shut off 2-3 sec and will repeat this and won't stop for as long as you have the key on!!!! I bought a brand NEW cpu,thinking that was my problem!!!! Because the flash is not consistent with the list of codes!! I installed the new cpu and got the same thing!!!! So its not the cpu!! So then I thought maybe its a code 1 which is an Oxygen Sensor! I bought a brand NEW O2 sensor!! I went through the process of resting the cpu, started the car and the light came back on right away!!! Same Flash!! Now if I go through and unplug sensors and check the CEL it will read each one thats unplugged,the it will do the one long flash after another at the end!!!! over the last few weeks when I'm driving at a steady speed the car will start cutting out like its not getting fuel,if I push in the cluch it will idle fine and rev up like nothing is going on!as sooon as i let out of the clutch and try to maintain a steady speed it will start doing it again!! NOW if I just stop it to the floor it comes out of it and won't do it again the whole time I'm driving!!!! SOMEONE PLEASE HELP!!!!!!!!!!!!!!!!!!!!
