2005 Acura TSX Repair Question
Asked on June 5, 2009
2005 Acura TSX Vibration at 30 to 40 mph while accelerating
Shakes or Wobbles problem
2005 Acura TSX 4 cyl Front Wheel Drive Manual 40,000 miles
I have been experiencing vibrations from the rear of my car while accelerating. The vibrations start at around 50 Km/hr and end at 60 km/hr (30-40 mph). The vibrations appear to be originating from the rear right side of the car; the rear right window will sometimes rattle. Are there obvious signs to differentiate between a balance problem or a CV joint problem.
Answer
Replied on November 15, 2009
There are no axles in the rear, so you can pretty much be certain that it is either a wheel bearing or an imbalance in the wheel itself.
