2004 Acura TL Automatic window getting stuck + side marker
RMF
  • 2004 ACURA TL
  • 6 CYL
  • FWD
  • 102,000 MILES
I'm having a problem with the front passanger side auto up window. Specifically, there are times when the window will partially roll up, then stops, then goes back down. This only happens when using the auto up button. If I manually hold the window up button, the window rolls up fine. This problem does not happen all the time. I'm thinking some type of sensor in the door. Any help would be appreciated.
Second, the right side side markers are popping off my TL. When I took a look at the side markers, it appears as though they are held in place by plastic clips which are on the side markers. The side markers are not broken. It just looks like the clips on the side markers are worn down a little. Is there a way I can fix the clips? My side markers are smoke color and expensive from the dealer. I'd rather fix them if possible.
Thanks!
Ryan
Tuesday, November 2nd, 2010 AT 4:30 PM
KHLOW2008
  • 41,815 POSTS
Hi RMF,
The auto up function is equipped with a pinch sensing system which is designed to reverse its movement if there are any restriction when the glass is moving up.
Check the door glass runnchannels. If glass runchannels are dirty or hardened, they would restrict the glass movement. Some silicone spry or waxed based lubricants might help to eliminate the problem.
For the side markers, if the clips are worn, get some masking tape to stick to the edges on the fender where the marker clips on to provide better grip for the clips.
Friday, November 5th, 2010 AT 12:30 AM
RMF
  • 11 POSTS
Thank you! I'll pass this information on to my service shop. Hopefully the problem can be fixed quickly.
On the topic of side markers, since the markers are clipped to the side of the car, is there a chance that water can leak through to the inside and hurt the car?
Thanks!
Tuesday, November 9th, 2010 AT 12:34 PM
KHLOW2008
  • 41,815 POSTS
The fenders are not designed to be waterproof and water can get behind it so there is nothing to worry about.
Wednesday, November 10th, 2010 AT 6:42 AM
RMF
  • 11 POSTS
So I took the TL to my repair facility. The technician told me that the reason the auto up function is not working properly is because of my aftermarket tinted windows. He said that when the tint was installed, small brushes inside the door that are used to remove dirt or something were removed. He said this is why the auto up function does not work all the time. Does this make sense? The other front window is tinted and I've never had a problem with the auto up? The technician told me he cleaned the track and lubricated the parts inside the door. Any suggestions? I'd really like my auto up windows to work. Should I go to Acura?
Thanks
Wednesday, November 24th, 2010 AT 5:24 AM
KHLOW2008
  • 41,815 POSTS
What did he use to lubricate the runchannels and does it work?
It is possible for the tint film to affect the door glass movement and if lubricating with silicone worsk, at least temporarily, the yu need to have a look at the runchannels.
If oil based lubricants had been used, the runchannel would be sticky and heavy fot the window. Replacement of the runchannel is the only option.
Wednesday, November 24th, 2010 AT 1:24 PM
RMF
  • 11 POSTS
I don't know what lubricants were used to clean the runchannels. All I know is that the problem is not fixed. The tech said the problem would persist because of the tint. My other window is tinted and the auto up works fine. Not sure what to do. Should I get those brushes put back onto the door? Do you think I should replace the runchannel?
Wednesday, November 24th, 2010 AT 2:58 PM
KHLOW2008
  • 41,815 POSTS
The tint is not the main problem but if the installation was bad, it can cause problems over time.
The small brushes mentioned meant the runchannel is worn and would stick. I would suggest replacing it.
Wednesday, November 24th, 2010 AT 6:11 PM
RMF
  • 11 POSTS
So, are you suggesting that I replace the runchannel? I also read that it could be the window regulator. I cleaned the runchannel out again this past weekend. I got a lot of black dirt out of it. I did not yet lubricate the runchannel. What type of grease should I use? Where can I get this grease?
As I said before, this only started to happen. The other auto window is tinted and the auto up works fine. This tells me that it is not the tint, but something else.
Last, do you know of a good repair facility in the San Fernando Valley of Los Angeles?
Thanks
Monday, November 29th, 2010 AT 10:09 PM
KHLOW2008
  • 41,815 POSTS
Use a silicone or waxed base lubricants. NEVER use oil based lubricants. Rubber treatment fluids works pretty well. At the parts store you should be able to get them easily.
If the runchannel works after lubricating it then it can rule out the possibility of the motor being the fault.
Have you tried to reset the motor?
Sorry, I am not located anywhere near LA so is unable to provide any recommendations.
Tuesday, November 30th, 2010 AT 1:15 PM
RMF
  • 11 POSTS
I have not tried to reset the motor. How do you do that?
When I get the silicone or waxed base lubricant, should I put a little in the runchannel and then move the window up and down to spread it through the channel or should I directly apply the lubricant throughout the entire channel?
Thank you!
Tuesday, November 30th, 2010 AT 5:07 PM
KHLOW2008
  • 41,815 POSTS
Resetting Power Window Control Unit
1. Turn the ignition switch ON (II).
2. Move the driver's window all the way down by using the driver's
window DOWN switch. ( DO NOT use Auto Mode)
3. Open the driver's door.
NOTE:
Steps 4-7 must be done within 5 seconds of each other. Refer to Fig. 3:
4. Turn the ignition switch OFF.
5. Push and hold the driver's window DOWN switch.
6. Turn the ignition switch ON (II).
7. Release the driver's window DOWN switch.
8. Repeat step 4-7 three more times.
9. Wait 1 second.
10. Confirm that AUTO UP and AUTO DOWN do not work. If AUTO UP and DOWN work, go back to step 1.
11. Move the driver's window all the way down by using the driver's window DOWN switch.
12. Pull up and hold the driver's window UP switch until the window reaches the fully closed position, then continue to hold the switch for 1 second.
13. Confirm that the power window control unit is reset by using the driver's window AUTO UP and AUTO DOWN function.
If the window still does not work in AUTO, repeat the procedure several times, paying close attention to the 5 second time limit between steps.
If you can spread the lubricants onto the runchannel, that would be the best. Firt try some lubricants on the runchannel and using the glass to do the work.
Tuesday, November 30th, 2010 AT 5:48 PM
KHLOW2008
  • 41,815 POSTS
Sorry I missed out the diagram
Tuesday, November 30th, 2010 AT 5:49 PM
RMF
  • 11 POSTS
OK, thank you. The instructions for the motor reset specify the driver's window. Is it exactly the same for the passanger window. Only using the passenger window button? Does it matter whether I use the driver's side passenger button or the actual passanger side button?
Tuesday, November 30th, 2010 AT 6:01 PM
KHLOW2008
  • 41,815 POSTS
Yes, for passenger window same procedures and either side switch can be used.
Tuesday, November 30th, 2010 AT 6:24 PM
KHLOW2008
  • 41,815 POSTS
Sorry, I must have clicked the wrong diagram.
Tuesday, November 30th, 2010 AT 6:25 PM
