Mechanics
ACURA TL ABS PROBLEM
1999 Acura TL
1999 Acura TL 6 cyl Front Wheel Drive Automatic 119, 00 miles
I have a 99 Acura TL. The other day I was almost home and the ABS light came on and the transmission felt like it slipped. I got home and just turned it off, when I went back out it wouldn't start, just some clicking. Jump started it and was fine but we tested the battery and it was bad. So I replaced the battery yesterday and thought the problem was solved. Well today I was driving and the ABS light came on again, the transmission started slipping and not going into gear, all my gauges stopped working. No clue where to even start on this problem.
Kshep221
August 26, 2010.
Hi kshep221,
I would suggest getting the charging rate tested first. Problem could be caused by low voltage due to bad alternator.
KHLow2008
Aug 27, 2010.
AD
