The windshield wipers do not work
2CP-ARCHIVES
  • 1997 ACURA INTEGRA
  • 4 CYL
  • MANUAL
  • 125,000 MILES
The windshield wipers do not work. They were working fine before it got stolen and when I got my car back they were not working any more. I have checked all of the fuses and even had to replace the combo switch because the washer motor would stay on. I thought that might have been the problem, but they still do not work. What should I check as my next step? I am guessing the wiper motor.
Thursday, October 7th, 2010 AT 11:41 PM
2CP-ARCHIVES
  • 4,542 POSTS
Do you hear the motor running? If so, it could be linkage related. If not, locate the motor and try wiring direct to current to bypass the switch. If the motor works, it is wiring and or switch.
Thursday, October 7th, 2010 AT 11:46 PM
SADA32
  • ACURA INTEGRA
I was dinking under the steering wheel and must have loosened a connection because my open door light is always on, the interior function on the windshield wipers does not work, nor does the rear defrost button, and the sound warnings for when my lights are left on do not work. So I guess my question is what connection did I knock loose, unplug, or short, where is it located. Thanks
Tuesday, December 20th, 2016 AT 2:38 PM (Merged)
F4I_GUY
  • 3,302 POSTS
Check for loose ground cables or connectors. You may also want to check your fuses.
SADA32
I checked all the fuses and they look good. I also noticed that the dome like does not work.
KHLOW2008
  • 41,815 POSTS
What is the year model?
SADA32
It is a 1995. I think F4I is right with the loose ground, but I do not know where to look. My Open Door Warning Light is only on when my dome light is switched to only be on when the doors are open. But it does not turn on.
KHLOW2008
  • 41,815 POSTS
The dome light is grounded at the light assembly itself and is not related to any other ground circuits. To check the dome light ground.
The door ajar light is not related to an open ground, in fact it is caused by the door switch wire being grounded or the door is not closing correctly to leave the switch activated.
Ground for intermittent wiper is located at left side of instrument panel.
Intermittent wiper relay is also controlled by the integrated control plugged into the fuse box.
JOEPRO15
  • 1991 ACURA INTEGRA
  • 4 CYL
  • FWD
  • MANUAL
  • 247,000 MILES
Four cylinder front wheel drive manual 247,000 miles.
My car has electrical problems like the windshield wipers stopped working and most of the wiring is jerry rigged from the person that owned it before me. When running the air conditioner at the same time driving it it starts to overheat so I am wondering what to do?
  • 31,938 POSTS
Hi there,
With a problem like this you need to see the problem first hand. Any non standard wiring alterations can be a real nightmare at best of times and to try and unravel this from here is just impossible. You will have to have a mechanic to check this out for you.
Mark (mhpautos)
