Engine Cooling problem
1987 Acura Integra 4 cyl Automatic 277524 miles
Hello; I just picked up this car and was told when I
bought it that it overheated within 15 mins. & that
they thought it was the water pump.I've since filled it
up & checked the water pump & could find no leaks.
What it does is when you pour water/antifreeze in,you can heard & see it running out from the bottom.I tried to see where it was leaking from,but
could not find the source.It seems to be coming
somewhere from the side of the engine facing the
firewall.Any ideas??? because I can't figure it out,&
can't afford to take it to a shop.Any help you could
provide I would REALLY APPRECIATE!!!!! Thank-you
Feb 17, 2009 at 2:40 PM
