Mechanics
ABS AND BRAKE LIGHTS COME ON SPONTANEOUSLY AND SPEED AND RPM GAUGES MALFUNTION
1998 Dodge Ram • 191,000 miles
I have a 1998 Dodge ram 1/2 ton pick up 4x4 - automatic - the ABS and Brake indicator lights come on when I hit a bump and also the rmp and mph dials go to zero and then bounce back up. Please advise.
Reztown
June 5, 2013.
Check you brake fluid level. It's probably a little low and if it is, check the wear on your brake pads because that's likely were it went.
Wrenchtech
Jun 5, 2013.
