Mechanics
A/C DASH LIGHT AND A/C WILL NOT COME ON
1996 Nissan Altima • 250,000 miles
The A/C was working fine last summer and when I went to cut it on this season no cold air and now the dash light will not come on. The car was worked on and the panel was dropped to repair an ignition switch, but I believe the A/C worked fine after that.
Jusimagin331
May 21, 2013.
Check if the compressor is engaging when A/C is turned on.
Check the fuses for the dash ilumination. Ensure the dimmer control is not turned to minimum, if equipped.
KHLow2008
May 21, 2013.
