Saturnhelp
SATURNSL2MAN
  • 26 POSTS
I know it had a bad wire on it also, i'm not sure if that has anything to do with it or not.
Saturday, July 28th, 2012 AT 12:47 AM
  • 30,870 POSTS
The wire melted to the exhaust manifold?Thats probably because of the wire.
Saturday, July 28th, 2012 AT 1:00 AM
SATURNSL2MAN
  • 26 POSTS
Yeah! It was in pretty bad shape.
Saturday, July 28th, 2012 AT 1:05 AM
  • 30,870 POSTS
Usually the plastic clip that holds the wire to the fan shroud breaks or comes unclip and it burns on the manifold. Make sure you route wire correctly and zip tie the wire to the shroud if you have to. So that it wont happen again.
Saturday, July 28th, 2012 AT 1:11 AM
SATURNSL2MAN
  • 26 POSTS
Ok! The bad wire was on the o2 sensor side, thanks for the tips.
Saturday, July 28th, 2012 AT 1:18 AM
  • 30,870 POSTS
Your welcome they dont get damaged if the wire is routed and secured properly.
Saturday, July 28th, 2012 AT 1:43 AM
SATURNSL2MAN
  • 26 POSTS
I definitely made sure of that this time so it doesn't happen again, thanks.
Saturday, July 28th, 2012 AT 2:00 AM
  • 30,870 POSTS
Your welcome anytime.
Saturday, July 28th, 2012 AT 2:02 AM
