Car stalls when it warms up
KHLOW2008
  • 41,815 POSTS
The big one is not. That is the Park and Neutral position switch. There are 2 wires running of it but I can't see it going to where. That could be ne.
Saturday, September 22nd, 2012 AT 7:19 PM
RMONET2012
  • 46 POSTS
Is it easier to get to the TCC from below?
Saturday, September 22nd, 2012 AT 7:36 PM
KHLOW2008
  • 41,815 POSTS
I am not sure about that.
Saturday, September 22nd, 2012 AT 7:43 PM
RMONET2012
  • 46 POSTS
This is the right side, can you point out where the TCC is located?
Saturday, September 22nd, 2012 AT 7:49 PM
KHLOW2008
  • 41,815 POSTS
It is inside transmission with the valve body. Ecternally it is identified by a Tan/Black wire. At transmission you should see some wires going into the transmission and one of it is the TCC wire.
Sunday, September 23rd, 2012 AT 5:27 AM
RMONET2012
  • 46 POSTS
Do I have to put the car on ramps to get to where the TCC is?
Monday, September 24th, 2012 AT 8:57 PM
KHLOW2008
  • 41,815 POSTS
To get at the wire connector, not necessary, if you are taking the valve body out, yes.
Monday, September 24th, 2012 AT 9:33 PM
RMONET2012
  • 46 POSTS
Is the TCC inside the valve body?
Here is a photo; can you arrow where to look for the TCC.
Monday, September 24th, 2012 AT 9:49 PM
KHLOW2008
  • 41,815 POSTS
It it INSIDE the transmisson together with the valve body. You can't see it from outside and the picture you provide does not even show the wires. Refer to the diagram you posted about the Park and Neutral position switch, it is somewhere near there.
Monday, September 24th, 2012 AT 9:59 PM
