AMC Javelin cranks, has spark and gas in the carburetor but still wont start
SPARKY1234
  • 1968 AMC JAVELIN
  • 72,000 MILES
Javelin cranks over, has spark and I poured gas in the carburetor and it still wont start.
Tuesday, December 27th, 2011 AT 4:21 AM
CJ MEDEVAC
  • 11,004 POSTS
WHERE DID YOU LOOK FOR SPARK?
IS THIS POINTS?
THE MEDIC
Tuesday, December 27th, 2011 AT 4:23 AM
SPARKY1234
  • 61 POSTS
We looked for spark by putting a screw driver in the spark plug wire. Yes it is points
Tuesday, December 27th, 2011 AT 4:27 AM
  • 108,170 POSTS
Are you getting a good hot blue snapping spark? If you have fuel and spark, it has to run unless the compression is too low, timing problems, or a weak spark.
Tuesday, December 27th, 2011 AT 4:30 AM
SPARKY1234
  • 61 POSTS
Thanks
Tuesday, December 27th, 2011 AT 4:34 AM
CJ MEDEVAC
  • 11,004 POSTS
ENGINE OFF
MANUALLY TURN CRANK TILL POINTS ARE CLOSED
WITH SOMETHING INSULATED (PEN, STICK, ETC) OPEN POINTS OVER AND OVER
DO THEY SPIT AND POP NICE SPARKS?
ANYTHING RECENT HISTORY OR DONE THAT MIGHT HELP ME?
THE MEDIC
CJ MEDEVAC
  • 11,004 POSTS
TURN THE KEY TO "ON" WHEN YOU OPEN THE POINTS!
SORRY
THE MEDIC
Tuesday, December 27th, 2011 AT 4:35 AM
CJ MEDEVAC
  • 11,004 POSTS
WHEN CRANKING
DOES IT SPIT AND SPUTTER LIKE IT WANTS TO BUST OFF?
OR IS IT JUST DRY OVER AND OVERS?
IF YOU PUT MUCH MORE FUEL IN IT THAN, LETS SAY 3 PLASTIC SODA BOTTLE TOP-FULS IT MAY BE FLOODED
HAVE YOU BEEN CHOKING IT?
HAS IT BEEN RUNNING?
THE MEDIC
Tuesday, December 27th, 2011 AT 4:46 AM
  • 108,170 POSTS
Which engine do you have in this car, and do you have any interest in the sale of it?
Tuesday, December 27th, 2011 AT 5:00 AM
SPARKY1234
  • 61 POSTS
It doesn't even make a pop like it wants to start but the battery was half way dead and it has been sitting for allot of years. It is a six syl.
Tuesday, December 27th, 2011 AT 4:26 PM
SPARKY1234
  • 61 POSTS
I think it is because the battery is dead
Tuesday, December 27th, 2011 AT 4:42 PM
  • 108,170 POSTS
How long has it been sitting? Also, did you replace the fuel, clean the carb, check plugs, wires? And yes, a weak battery can have an affect on it.
Tuesday, December 27th, 2011 AT 6:37 PM
CJ MEDEVAC
  • 11,004 POSTS
SO IT'S EITHER A 232 OR A 258
BASICALLY THE SAME ENGINE EITHER WAY
MY '77 JEEP HAS A 258 W/ ELECTRONIC IGN---I HAVE REPLACED THE INTAKE AND INSTALLED A 4 BBL HOLLEY
MY OTHER JEEP HAS A FLATHEAD FOUR, IT'S A 1946 WILLYS
RECENTLY I REPLACED THE POINT SYSTEM WITH AN ADD-ON ELECTRONIC SYSTEM AND COIL (ONLY THE DISTRIBUTOR PARTS AND COIL, NO OTHER BOXES OR WIRING)----VERY SIMPLE AND INEXPENSIVE, FITS RIGHT INTO THE EXISTING DISTRIBUTOR. CAN BE REVERTED BACK IN MINUTES, IF NEED-BE
I LIKE IT A LOT--LET ME KNOW IF YOU ARE INTERESTED, I'LL SEND MORE INFO--I FEEL SURE THE COMPANY MAKES THE SYSTEM TO FIT YOURS
THE MEDIC
Tuesday, December 27th, 2011 AT 7:54 PM
SPARKY1234
  • 61 POSTS
To the medic. Well I found out it is a 1968 javelin SST and yesterday I found the problem, it is because the carburetors throttle was rusted shut. It runs and I hooked up a temporary fuel tank that is a 1 gallon tang and its gravity flowed from the roof. We are hot wiring it from under the hood because of no key. Nice jeep but I'm not interested because I just turned 13.
Thursday, December 29th, 2011 AT 2:16 AM
SPARKY1234
  • 61 POSTS
To the medic. I have a friend that is interested in the 46 willies and wants to know more info and the price.
Thursday, December 29th, 2011 AT 2:23 AM
CJ MEDEVAC
  • 11,004 POSTS
CAN'T GET RID OF WILLY. HE'S MY BABY. THERE ARE MANY MORE OF 'EM
IN CASE YOU WANNA GET RID OF THE POINTS, HERE'S THE LINK TO THE MFGer's CATOLOG---YOU CAN FIND WHAT YOU NEED HERE, THEN YOU'LL HAVE TO TAKE THE PART # TO ONE OF THEIR DEALERS TO PURCHASE
I'M JUST GUESSING YOU HAVE A 2 BARREL BBD
THAT'S HARD TO BELIEVE THAT'S THE SAME CARB--BOTH HAVE WARRANTY'S---I WOULD NOT BE SCARED OF THE CHEAPER ONE
ALWAYS KEEP YOUR CORE UNTIL ALL IS RUNNING WELL, THERE MAY BE A BRACKET, ETC THAT YOU NEED TO TRANSFER TO THE REPLACEMENT. NOTHING LIKE YOUR CORE BEING GONE FOREVER AND YOU NEED SOMETHING OFF OF IT.
ARE YOU GETTING THIS PUPPY FIXED UP FOR WHEN YOU ARE LEGAL ROAD READY?
WHEN WE MESS AROUND WITH A "DRAG IN" JEEP, WE DO THE GAS CAN THING TOO---WE CALL IT THE "I.V."!
KEEP US POSTED ON PROGRESS
MAYBE WE CAN HELP SOME
THE MEDIC
Thursday, December 29th, 2011 AT 4:17 AM
SPARKY1234
  • 61 POSTS
I probably will get it when I'm 16. Thanks for the sites. Ill keep you posted on the progress. Thanks!
Thursday, December 29th, 2011 AT 5:25 AM
CJ MEDEVAC
  • 11,004 POSTS
WE'RE WAITIN' ON YOU
THE MEDIC
Thursday, December 29th, 2011 AT 5:52 AM
