425 bigblock stalls
MOPARMAN 01
  • 1965 OLDSMOBILE 88
  • 73,000 MILES
When I drive down the road the car stall let it sit for a little while it will start back up the coil is new and the points are new could that have something to do with the starter? Please help
Do you
have the same problem?
Sunday, October 9th, 2011 AT 1:26 AM
  • 52,797 POSTS
Sounds more like carb issues than electric. That motor runs very hot and if the float level is low, it would tend to boil the fuel and thats when the motor stops.
I would be looking at the fuel delivery system.
Sunday, October 9th, 2011 AT 1:30 AM
MOPARMAN 01
  • 17 POSTS
Thank you I will check the carb and let you know
Sunday, October 9th, 2011 AT 1:33 AM
  • 52,797 POSTS
By the way, do you have the quadrajet or the wcfb?
Sunday, October 9th, 2011 AT 1:41 AM
  • 108,005 POSTS
I agree with ase. It sounds like a fuel related problem. As he mentioned, these engines commonly ran hot. I would first check for vapor lock with the fuel. If that isn't it, the only other thing I can even think of that could do this is the wiring to the ignition system. Back then, 12 volts were fed to the ignition system on start up only. After that, there was a resister wire that dropped the voltage to 9 volts to protect points, condenser. It helped things last longer. You may want to check the resister wire for thermal issues too.
I love these old cars, but I hate to show my age. (Lol) Acttually, I wasn't born when the car was made. But I worked on a lot of similar vehicles and ones just like your when I was very young.
Let us know what you find. Remember, as ASE said, they ran hot and fuel vapor lock was an issue.
Sunday, October 9th, 2011 AT 1:42 AM
MOPARMAN 01
  • 17 POSTS
The thing is when it stalls and you try to crank it you can smell gasin the carb?
Sunday, October 9th, 2011 AT 2:20 AM
  • 52,797 POSTS
Ok, it could be leaking down from the bottom of the carb. I think we are on the right track for you.
Sunday, October 9th, 2011 AT 2:54 AM
MOPARMAN 01
  • 17 POSTS
Could it be fuel filter in the in the carb?
Sunday, October 9th, 2011 AT 3:00 AM
  • 52,797 POSTS
Not likely. It has a bypass when it gets clogged
Sunday, October 9th, 2011 AT 3:07 AM
MOPARMAN 01
  • 17 POSTS
I will check the bottom tomorrow to see if thats it it might be the gasket?
Sunday, October 9th, 2011 AT 3:12 AM
  • 52,797 POSTS
You may need to remove the carb and look underneath it to see if the 2 plugs at the bottom are leaking.
Sunday, October 9th, 2011 AT 3:13 AM
MOPARMAN 01
  • 17 POSTS
Will check that out and let you know
Sunday, October 9th, 2011 AT 3:19 AM
  • 52,797 POSTS
Not the gasket, you are looking for fuel leakage under the carb.
Sunday, October 9th, 2011 AT 3:30 AM
MOPARMAN 01
  • 17 POSTS
Does any one know where I can find vacuum diagram for that car
Saturday, October 15th, 2011 AT 2:19 AM
MOPARMAN 01
  • 17 POSTS
I am going to look at it tomorrow
Saturday, October 15th, 2011 AT 2:20 AM
  • 108,005 POSTS
I wish I had one for you, but our manuals only go back to about 1975. Chances are you will need to order a manual from a book store or auto parts store.
Saturday, October 15th, 2011 AT 2:35 AM
