Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair & Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Discount Auto Parts
Vehicle Repair Online Repair Manual
Vehicle Repair Car Maintenance
Vehicle Repair Car Safety Information
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Forum Topics
Auto Repair1995 Chevy Tahoe O2 Sens...
Auto Repair1997 Other Plymouth Model...
Auto Repair1986 Other Isuzu Models I...
Auto Repair1999 Volkswagen Jetta Ra...
Auto Repair1998 Dodge Neon Overheating
Auto Repair1991 Other Mercedes Benz ...
Auto Repair1996 Volkswagen Jetta Ai...
Auto Repair2001 Ford Windstar Plugs
Auto Repair1993 Ford Explorer Stalling
Auto Repair1995 Other Gmc Models Cra...
Auto Repair1998 Ford Explorer Keys
Auto Repair1997 Hyundai Accent Chan...
Auto Repair2001 Ford Windstar Shutt...
Auto Repair1965 Cadillac Deville Wh...
Auto Repair1994 Ford Explorer Air C...
Auto RepairMore Forum Topics...
Locate Auto Parts
Latest How-To Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Automotive Repair Forum
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
Windshield wipers/pump intermittant
Posted at Tue Nov 06, 2007 8:39 am
By pnkdimnd, New to the forum
Give Feedback | Votes: 0
I have a 2000 BMW 323i with 95K and a 2.8L (I believe) engine. About a month ago the wipers/pump started becoming intermittant. At first they would not operate when I first turned on the vehicle and engaged the wiper blades/pump from the steering column, however they would operate after 5-10 minutes. Sometimes the pump would operate, however with no blade movement. Then they both started to not operate at all, or operate for a few minutes then fail or get stuck in a vertical position and stop. The pump always appeared to work when the blades are working. Now it seems neither are operating at all or only for one movement then stop. I understand that there is a relay module, a switch mechanism and a pump/motor assembly... I took the vehicle to BMW service at first, however they could not diagnose the condition as the system seemed to be operating normally at the time. They stated the relay and switch were good which makes me believe these parts are accessable from the engine compartment. They estimated the cost of repair around $800 based on the need to still diagnose the problem. The cost of all the parts are 1/4 the repair cost and I would anticipate I could repair it if I knew what mechanism is likely to be at fault. Could someone please assist in helping to diagnose the likely cause of this problem and the location of these parts? I know the pump/motor is located behind the glove box, however where is the relay module and switch mechanism located? I assume the control from the steering column goes to the relay first to power the switch and then provide control signals to the pump/motor assembly, however I could be wrong... any assistance would be so much appreciated. Thank You.
Find a repair manual for your BMW 323 Repair Question.
Posted at Tue Nov 06, 2007 8:57 am
By Dr. Hagerty, Moderator
Reputation: 102.7Reputation: 102.7Reputation: 102.7Reputation: 102.7Reputation: 102.7 (103) Give Feedback | Votes: 6
the wiper relay (or module if you please) is in the plastic box in the engine compartment, left side of the car, up against the firewall. Loosen the 5mm Allen head screws, and inside the box in the back corner is a green-brown relay(part # 61-36-8-384-505) let me know if this helps and keep in touch.
Make a small donation! (We will make sure your question will be answered promptly)
Reply to topic
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins.Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
Computer Repair
