Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 12,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
Common Toyota truck V6 engine problems.
Posted at Sat Apr 22, 2006 6:42 pm |
By
losone,
2CarPros Level 5 |
(86) Give Feedback | Votes: 1 |
I see many posts for Toyota trucks with a V-6 engine with problems with loosing coolant, pulsing water in the radiator, water inside the engine or unknown engine misfire.
Toyota has known for a long time they have had problems with their headgaskets. They have issued a non-published recall (VO-6)to correct the problem. |
| Find out more about your Toyota Pickup Repair Question: NEED MORE
TECHNICAL INFO? Car Repair
Manual - Questions by Topic -
First Things to Check - How to Car Repair - How Does it Work?
- Donate Here |
Posted at Sat Mar 03, 2007 11:28 am |
By
skywalker165043,
New 2Carpros Member |
Give Feedback | Votes: 0 |
I have been reading about the head gasket problem and would like to know if it is particular to one side or the other. My 5vzfe with 95k miles, is running strong, but has a loud valve tappet at the number one cylinder. I am losing coolant from the recovery tank slowly, and cannot find any external leaks. I have a lot of condesation coming from the exhaust during warnup and strong sulfer smell. My next test would be a compression/cylinder leak down. I just replaced the plugs "bosch twin Platinum" and oil change to mobil 1, 5w30. mileage is getting better, around 19-20mpg. I just replaced the timing belt and water pump, original pump was weeping. Have been looking at replacing both HG's with Felpro kit. And then adjusting valves. No oil leaks. DO you recommend valve grind, head resurfacing before assembly? |
- Donate Here |
Posted at Sat Mar 03, 2007 12:03 pm |
By
losone,
2CarPros Level 5 |
It is a common failure on your engine. I strongly recommend you visit a Toyota dealer ship and get the job done free under recall VO6. No 1 or 2 cyls are the first to go and then it will need gaskets.
Toyota recognizes the problem. Make sure you replace the knock sensor when the job is accomplished as it is under the intake.
Don't wait too long. Water is not compressable and you could suffer piston and head damage. I have seen Toyota replace both heads at no cost.
Good Luck and let me know
Losone |
- Donate Here |
Posted at Sat Mar 03, 2007 12:19 pm |
By
skywalker165043,
I thought about that, but wasn't sure if my truck would be covered under the recall? The local yoyta dealer is just up the street, I should make an appointment. thanks.
I have never been a big fan of the dealership maintenance. I've always done all my own work, but this seems to be very involved work and time consuming. what would be a average estimate for them to complete the job? would thry do both heads? I just spoke to the dealer and they told me my vin was not covered by the recall? said that i could ignore the loss of coolant and if it gets worse would basically have to pay for the repair? I have read that some customers hve gotten stiffed by there dealers too! |
- Donate Here |
Posted at Tue Oct 23, 2007 2:00 am |
By
cherryjerry,
How can I find out information on this recall? I have a 91 pick up, V6, 4wd, 5 speed.
Toyota has known for a long time they have had problems with their headgaskets. They have issued a non-published recall (VO-6)to correct the problem.[/quote] |
- Donate Here |
Posted at Tue Oct 23, 2007 7:55 am |
By
2CarPros Jack,
Certified ASE Technician |
  (1320) Give Feedback | Votes: 132 |
There are a couple of earlier posts with links to some of the info. Best bet is to go to Toyota dealer and talk to them, be the squeeky wheel, and you will get greased.Spent a few years at a dealer and seen it many times. Do you have maintenance receipts for the cooling system and such? that would help your cause if the truck wasnt neglected, just poor design |
- Donate Here |
Make a small donation! (We will make
sure your question will be answered promptly)
