Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1994 Ford Probe Cars Di...
Auto Repair1993 Jeep Wrangler No Heat
Auto Repair1991 Subaru Legacy Pist...
Auto Repair2000 Honda Accord 2000 ...
Auto Repair1996 Chrysler Cirrus Va...
Auto Repair1995 Toyota Camry
Auto Repair1994 Chrysler Cirrus Tr...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
Very strange problem with the Trans. NEED HELP PLEASE!
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Mon Oct 29, 2007 2:09 am
By Moose5255, Likes cars!
Give Feedback | Votes: 0
I have a 1993 Mercury Tracer, (station wagon) 4 cylinder (2.3 liter) and the car has 146,000 miles on it. The car has a "new" tranny taken from a junk car, the original had a major meltdown and it needed to be replaced, so my mechanic friend replaced the original with one from another Mercury Tracer which had approximately 70,000 miles on it. My problem is, the transmission (they call it a trans axle I guess) is acting up. It takes off in first gear fine but won't shift. If I put it in neutral then back to drive (the drive that shows the "D" in a circle) then it shifts to the next gear. BUT, after a few seconds it slips out of gear. Then I repeat the process and again, it shifts to the next gear only to slip out again! Now, after awhile it will down shift by itself, stay that way for a few seconds, then it will straighten out and shift through the gears just fine. Sometimes it takes only once or twice to get it to shift correctly, but other times it will do this for up to 5 or 10 miles. It is strange and frustrating, even to my mechanic who is very good. The gears do not slip, it just pops out of gear. It's very annoying and also I'm afraid it might be a prelude to a major problem. Do you have any suggestions? Thank you in advance! (P.S. I am a disabled person on a fixed and very tight income, but will make whatever donation I can when I receive my monthly check for November 2007. Right now though I desperately need my car).
Find a car repair manual for your Mercury Tracer Repair Question.
Posted at Mon Oct 29, 2007 7:36 am
By 2CarPro Jack, Certified ASE Technician
Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5 (682) Give Feedback | Votes: 80
Assuming that you did service the trans, so a plugged filter isnt an option. Could be a sticky governor or something in the valve body from the trans sitting for a while. Try a flush, it might help free up whatever the problem may be
Posted at Mon Oct 29, 2007 7:47 am
Yes, the transmission fluid was drained, filter replaced with a new one. How do I flush the tranny, and What do I use to flush it, and do I need to replace the filter again after it has been flushed? Thank you.
Posted at Mon Oct 29, 2007 8:06 am
A trans shop will have the right equipment to do a full flush......might help and might not.
Posted at Mon Oct 29, 2007 1:44 pm
Thanks so much I appreciate your suggestions. Will let you know if flushing it helps out. Thanks again!
Posted at Fri Oct 03, 2008 6:00 pm
By rodbearing, New to the forum
i have the same exact problem with my 93 tracer, i found some bad vacuem lines i thought,might be the problem ,but it was not,my next move is tranny flush,fluid filter,somthing is not telling this tranny to shift,i will let you knowif i fix this thing
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
