i have a 1985 buick electra park ave. with a 3.8l v6 4 speed auto. with roughly 200,000. the trans will take of in all gears, but when it trys to shift auto it goes out of gear, till it gets the rpms down. have replaced trans modulator and all vacuum hoses, egr vacuum solinoid, tested the v.s.s and it was just fine i am lost please help!!!!!!!!!!!!!!!!!!!!!!
Find a
repair manual for your Buick Electra Repair Question.
Posted at Mon Oct 15, 2007 1:09 pm
By
Advertisment,
Find a
200k ? Is the fluid level correct? Has the trans ever been done before? Sounds like a little bigger problem than just the mod.Might be time for a rebuild
Find a
thank you for your help the trans fluid level was fine, so i took it to the shop to get a used one in its is alot cheaper. with putting an old one in should the fluid and filter be changed plus new o-rings put in. thanks you again for your help.....
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
