I have a 2001 century custom. I have a noise that sounds like tappets. My mechanic has changed the springs and valves twice. The noise still persists. Oil has been changed four times, noise is still there. Any body have any ideas.
Thanks
Thanks
I have a 2001 Buick Century and the tappets are rather loud for the first minute or two. Then they quiet down. This is just the opposite of what normally should happen. When the engine is cold and the oil is thick (viscosity) the moving parts in the motor have thicker oil in them and the motor should be quiet. Why the tappets clatter is a mystery unless the hydraulic lifters dont pump up real fast. Let me know if you find anything out.
Find a
repair manual for your Buick Century Repair Question.
Thanks
As your vehicle sits most of the oil will drain down into the pan. when you start your vehicle the oil needs to be pumped up through the engine so, there will be a tapping noise for a few seconds after start up.
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
