Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2002 Ford Fiesta Fan
Auto Repair2000 Ford Windstar Knoc...
Auto Repair1967 Pontiac Bonneville ...
Auto Repair1997 Chevy Cavalier Tac...
Auto Repair2003 Mazda Protege Prot...
Auto Repair1997 Mazda Protege
Auto Repair1994 Ford Explorer 4x4 ...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
rough idle
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Tue Aug 14, 2007 7:23 pm
By star52, Likes cars!
Give Feedback | Votes: 0
My 93 geo 1.6l won't idle smoothly. Will even stall at complete stops. Replaced plugs, wires, cap, rotor. ECM tells me nothing wrong. I suspect MAPP sensor but it checks out okey. I've adjusted idle up and advanced timing by turning distributer to keep it running. This can't be good for to long. Is there something I've missed? Does anyone have any ideas what I should?
Find a car repair manual for your Geo Storm Repair Question.
Posted at Wed Aug 15, 2007 12:44 am
By rasmataz, Certified 2CarPros Master Technician
Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9Reputation: 988.9 (989) Give Feedback | Votes: 75
14yo car and has a 1/2 tune-up-my friend there's more to it especially my way.
Do you know how to track a vacuum leak?
If it has an EGR and PCV valves find them and clean it make sure its getting vacuum to it, then comeback and we'll take to the next level of the engine conditions.
Good Luck
Posted at Fri Sep 19, 2008 6:39 am
By justaluckyshot, Likes cars!
Like the prior poster said, check for vacuum leaks. First off, back the off on the timing, take it back to 10 Degrees TDC cyl 1.
If all else fails, take the engine back to stock, you know?
Replace all vacuum lines, its like 7 dollars for a 3 ft tube, just remove one, cut a new one, replace. dont mix up the tubes to wrong holes though =)
once you replace all the tube, take a can of starter fluid, with a straw attached. spray in short bursts all around any intake. vacuum lines, all around the throttle body, the EGR, the carbon canister, everywhere that goes into the motor.
If the motor goes WAAAAAY up in idle (its starter fluid remember =P) then you have yourself a leak.
If no leaks are found, pull up on the bottom of the EGR valve, does the motor try and die? If its already dying, maybe the EGR valve is stuck open? That would be my best bet honestly. Does it idle Strong, but low? Or low and weak, like sick sputtering sounds? Shaking real bad?
If the EGR valve checks out, check your cam timing. Pull off the Belt cover, lower the engine if you can, and check to see if those white marks line up. on the DOHC the white lines should FACE EACH OTHER, and be INLINE WITH THE HEAD. If not, adjust accordingly. The SOHC Geos cam timing lines up with a white mark, running with the head, and a black mark pointing to 12 oclock. Go check a manual, like Haynes, for more info.
If it aint your Ign timing, Cam timing, Vac leak, EGR, or IAC/TPS. well my friend, im out of ideas.
=D hope I helped!
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
