Make: Acura
Model: RSX-S
Year: 2004
Engine Size: 2.0L
Mileage: 65k
Last alignment: about 4 mos ago.
I am getting a popping noise from my front suspension when the sterring wheel is turned under load (car on jack stands does not make noise when wheel is turned). This noise will occur when the vehicle is both stationary and in motion. I have taken the front sway bar off and inspected the end links (no problem) I have removed the front sway bar and turned the wheel while the vehicle is not in motion (underload) and get a pop at the same point in wheel revolution.
I have inspected the tie rod end boots and there are no tears that I can find. Any suggestions? maybe a loose bolt from alignment?
