Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2003 Pontiac Sunfire ???
Auto Repair2000 Honda Civic Overhea...
Auto Repair2001 Other Saturn Models ...
Auto Repair1991 Honda Accord Overhe...
Auto Repair1994 Mercury Capri Capri...
Auto Repair1998 Nissan Pathfinder K...
Auto Repair2003 Nissan Pathfinder P...
Auto Repair2001 Nissan Pathfinder S...
Auto Repair2000 Nissan Pathfinder
Auto Repair2001 Nissan Maxima Fuel
Auto Repair1991 Nissan Maxima Fuel ...
Auto Repair1994 Nissan Maxima Filters
Auto Repair1992 Nissan Maxima Noise...
Auto Repair2000 Nissan Maxima Front...
Auto Repair2005 Audi A6 Car Can't D...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
Popping Back Threw Intake
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Mon Nov 05, 2007 9:23 am
By thesellars, New to the forum
Give Feedback | Votes: 0
Hello i im working on grandparents Buick Electra Limited with the 3800.It Has 110,000 Miles And When Running it has a popping noise coming from intake sounds like popping pop corn.I replaced plugs just to be sure but no better.Can U Please Give Some Advice.
Edit 11/06/07
Removed Front Valve Cover And Had Broken Exaust Rocker Arm Bolt.Replaced Rocker Arm Bolt And Works Fine.Thanks I Hope This Helps Others
Edit 11/06/07
i Have Another Question Before The Rocker Arm Bolt Broke The Car Was Always Hard To Start When Its Cold If The Engine Is Hot It Will Crank Fine,I Was Hoping that The Rocker Arm Might Have Had Something To Do With It,But U Still Have To Spin It Over 3-4 Times For 5-6 Seconds And It Finally Cranks.I Done A Tune Up On It After I Replaced The Rocker Arm Bolt Which Included Plugs,Plug Wires,Oil,Oil Filter,Fuel Filter,PCV Valve,and Air Filter Still Has To Spin Over 3-4 Times Before It Will Crank Any Ideas Or Test That Might Help Fix This Problem.
Find a repair manual for your Buick Electra Repair Question.
By Advertisment,
Posted at Wed Dec 12, 2007 4:21 pm
By ghas, Likes cars!
Hi , sounds like fuel pump relay , gm uses the relay to turn the fuel pump on for 3 seconds when the key is turned on , after that it uses oil pressure to keep the pump on , have someone at the rear of car turn on key dont start just turn on listen by fuel tank for pump , if you dont hear it replace relay. If you do check fuel presure .
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
