Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1997 Ford Explorer
Auto Repair2000 Mercury Sable Conn...
Auto Repair1997 Subaru Outback Ant...
Auto Repair2006 Chrysler Town And C...
Auto Repair1998 Jeep Cherokee No H...
Auto Repair2004 Ford Mustang Stuck...
Auto Repair1998 Cadillac Deville Ru...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
Please Help have no wheels. (UPDATE)
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Jul 07, 2007 11:32 pm
By marco, New to the forum
Give Feedback | Votes: 0
96 Aerostar V-6 3.0 Lit. Multiport EFI Mileage 110
Was losing power and stalling (complete shut off) occasionally while driving, if stopped at red lights especially after a long highway run. Would run fine for weeks and then stall again without apparent reason. A friend suggested a failing in-tank fuel pump, replaced it. the new pump primes and it seems ok, but engine wont even start now, it cranks and no go. tried to hand spray fuel directely in trottle body, it starts and it runs as long as I keep spraying fuel, if I stop it dies, apparentely it is not getting fuel on it's own. i was able to reach operating temp by spraying fuel and the engine would stay running on it's on once hot, but only at idle, if I accelerate a little it dies again. (UPDATE) I changed so far: fuel pump, fuel filter, spark plugs, PCV valve, Fuel Pressure Regulator, Air Bypass Valve, Ignition Coil, Fuel Pump Relay(s). Checked Spark OK. Fuel cutoff switch is reset. NO CHANGE. Checked if I get fuel out of pump and filter when cranking, lots of fuel coming out from both. What else can i do? Thank you a million.
Find a car repair manual for your Ford Aerostar Repair Question.
Posted at Sun Jul 27, 2008 1:29 pm
By papaloeh, New to the forum
Install a carb kit. That might do the trick.
Posted at Sat Aug 16, 2008 8:06 pm
By KHLow2008, Moderator
Reputation: 176.1Reputation: 176.1Reputation: 176.1Reputation: 176.1Reputation: 176.1Reputation: 176.1Reputation: 176.1Reputation: 176.1Reputation: 176.1 (176) Give Feedback | Votes: 12
Hi marco,
Did you check/test the Throttle Position Sensor?
Did you scan for DTCs ?
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
