I have a 1987 Buick Electra with a 3.8 litre v-6. It is not getting spark.I have replaced the ignition module,crank sensor,cam sensor,magnavox coil pack,harmoic balancer,timing chain,and cam interupter magnet.I still have no spark.my emil address is dobbins9412@yaoo.com.
Thanks
Find a
repair manual for your Buick Electra Repair Question.
Posted at Wed Nov 07, 2007 10:14 am
By
Advertisment,
Find a
Posted at Wed Nov 07, 2007 11:53 am
By
blackop555,Certified 2CarPros Master Technician
hook positive 12v from battery terminal to the positive terminal on the coil does it get spark now? also test if the coil is putting out the full amount of spark. if your model hs a distributor and rotor check for carbon build up, cracks, or a worn rotor.
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
