Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
i have a 93 geo storm i am getting only getting power to 1 prong on the plug to the coil.i put 2 new coils on it thinking the 1st new one was badbut nothing seems to work all fuses are good and i am lost this is my mothers car she said she was going down the road and it just died can someone please help me!! i just want this thing out of my yard i am redy to junk it thanks
thanks for the info. it doesnt show if power should come out of more than 1 prong on the plug. also if my timing belt broke will i get power thru the coil thanks again guys
First what engine and how many miles?
What is the problem that caused you to replace the coil. I assume it will not start. If this is the case then do you have spark?
I do believe that only 1 coil terminal should get power.
If the timing belt broke the rotor inside the distirbutor will not turn as the engine is being cranked over.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
