Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
1999 BMW 750il with a 5.4 12 cylinder. I did a tune up on it and now after the vehicle warms up it's making a ungodly howling noise down by the torque convertor area. But when you let the motor cool down and start it back up it goes away until it warms up again. What can this be? Is it something I did or pure coincidence?
could be the PCV valves on the back end of the plenum
(one on each side) it would make a sound like you described. to check this use a slack tube manometer at the crankcase, more than 6" of difference from side to side and that's where to start. repost if more help is needed
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
