Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
i have a 1971 BMW model 2002 and the car has been over heated quite regularly actually my brother was driving it to work and was overheateng it almost every day. so anyway long story short I noticed a sudden loss in power. so naturally I checked among numerous other things the compression. well they were all low i believe less than 30 psi. now this didn't make sense because i have put a set of high compression pistons in it. so i replace the head gasket and found out that the old one had in fact been leaking. i also checked for slack in the valve train and it is all within specs. however when i put the head back together and tested for compression again it is still low. i got between 30 and 45 unbalanced compression. so what should i check next?
I don't think you said what engine you had, but I would ask if the head was planed? Did yopu check both matting surfaces? Air can only leak where it's allowed to! A BMW this early no doubt has a steel timming chain...A warped head is most likly!
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
