Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Car Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Auto Parts
Vehicle Repair Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2001 Jeep Wrangler 2001...
Auto Repair1984 Ford F350 Feels Li...
Auto Repair1998 Nissan Altima Car ...
Auto Repair1995 Toyota Camry Engin...
Auto Repair1995 Ford Ranger 1995 F...
Auto Repair2002 Dodge Stratus Wind...
Auto Repair1999 Buick Park Avenue ...
Auto Repair1985 Mazda Rx7 Carb/fue...
Auto Repair1996 Chevy Truck
Auto Repair2004 Dodge Caravan Star...
Auto Repair1998 Ford Explorer
Auto Repair1996 Toyota Avalon
Auto Repair1995 Isuzu Rodeo Questio...
Auto Repair2006 Chevy Silverado
Auto Repair2002 Buick Lesabre
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Other Websites
Auto Repair Computer Repair Questions
Auto Repair Search Engine Optimization
Auto Repair WhyOurWorld.com
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
Lincoln Mark Vlll will crank but not start
Welcome to our question and answer forum were over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Fri Oct 19, 2007 8:02 pm
By shaegun, New to the forum
Give Feedback | Votes: 0
I have a 1997 Lincoln Mark Vlll, lsc. It has 112k miles, 4.6L V8
I have had a problem off an for the past 9 months. It will crank and not start, so it has been towed to the repair shop 5 times. 1st time it started when mechanic started it up and would not repeat problem so could not diagnosis it. 2nd time, they replaced "crank shaft sensor." 3rd time, again started up after being towed there, they did nothing. 4th time, they replaced spark plug boots on #4 and #5 cylinders. the computer test diagnosis dtcs PO355 ignition E coil pri/sec circuit fault. 5th time towed last week, started again and supposedly could not repair without having the problem there. Today, 10/19 again it will crank, but no start.
Why is this happening off and on and once it gets to the shop it starts. Is there a way to diagnosis the problem while it is working.
Any idea what might be causing this off and on problem and what should be repaired.
Thanks so much for any help.
Find a repair manual for your Lincoln Mark VIII Repair Question.
By Advertisment,
Posted at Sat Oct 20, 2007 4:36 am
By blackop555, Certified 2CarPros Master Technician
Reputation: 132.4Reputation: 132.4Reputation: 132.4Reputation: 132.4Reputation: 132.4Reputation: 132.4Reputation: 132.4 (132) Give Feedback | Votes: 24
yes check for bright blue sparks at the spark plugs. and fuel at the fuel rail if your getting both then id check the starter relay or ignition switch.
Posted at Fri Dec 21, 2007 6:59 pm
By frankyiroc, New to the forum
I have a 96 Mark VIII with the same issue. I have plenty of fuel pressure. I've changed the mass airflow, removed and cleaned the throttle body, replaced the IAC. The check engine light is now on and the code is a system too lean bank 2. I can't find any vacuum leaks. I've spoken to a dealership mechanic and he said it was the hydraulic tensioner on the timing chain losing pressure, throwing out the cam timing. When the pressure builds back up the engine would run like nothing happened. Before I tear into the motor, could this be possible?
Posted at Fri Dec 21, 2007 7:33 pm
yes, its possible but the code that is thrown is for the o2 sensor in bank 2 reading lean, more then likely it is a bad o2 sensor.
Posted at Fri Dec 21, 2007 7:48 pm
I have also noticed minor spark knock under light acceleration.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
