Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2003 Pontiac Sunfire ???
Auto Repair2000 Honda Civic Overhea...
Auto Repair2001 Other Saturn Models ...
Auto Repair1991 Honda Accord Overhe...
Auto Repair1994 Mercury Capri Capri...
Auto Repair1998 Nissan Pathfinder K...
Auto Repair2003 Nissan Pathfinder P...
Auto Repair2001 Nissan Pathfinder S...
Auto Repair2000 Nissan Pathfinder
Auto Repair2001 Nissan Maxima Fuel
Auto Repair1991 Nissan Maxima Fuel ...
Auto Repair1994 Nissan Maxima Filters
Auto Repair1992 Nissan Maxima Noise...
Auto Repair2000 Nissan Maxima Front...
Auto Repair2005 Audi A6 Car Can't D...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
GAS MILEAGE TIPS
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Fri May 16, 2008 4:21 pm
By blackop555, Certified 2CarPros Master Technician
Reputation: 132.3Reputation: 132.3Reputation: 132.3Reputation: 132.3Reputation: 132.3Reputation: 132.3Reputation: 132.3 (132) Give Feedback | Votes: 24
I will list my view of tips for getting the most you can out of gallon of gas.
Best thing and easiest to check is your tire pressure, fill up to the standards found on the inside of the door pillar usualy driver side. inflate about 2-3 psi over so you have less resistance when driving to further increase mileage, and if it goes down a few psi it wont drop bellow manafactur. specs.
second tip is accelerate slowly, let the vehicle shift through each of its gears slowly. about 1/4 throttle is near the best you can get, just keep the rpms in the middle.
third tip is drive 55-60 mph, anything over 60 mph can cut your gas mileage, your vehicles aerodynamics are best in the 55-60 mph range, anything over messes it up and not only does it create drag on the engine but it increases the RPMS using up more gas to maintain it.
Fourth tip- do the oil change ever 3,000 miles dont skimp on it, if you do it will come back to you in the end. clean oil helps the engine cool easier and cuts down on damage to the engine. imagine the amount of gas you can save with what would be spent on a new engine.
Fifth Tip- Tune up's are a necessary, take it in, make sure the air filter is clean, spark plugs are working properly, plug wires are good, you have nice clean spark that is on time. and many other things done with a tune up. Also fuel additives should be used every other tank, its a 4 dollar investment that will save you in the end.
Sixth tip- O2 sensors when bad can dramatically cut your gas mileage, as much as 1/4 of it can be dropped off, that is a lot!
Those are the tips i have to help you run your vehicle smoother and make it run longer.
and hopefully give you BETTER GAS MILEAGE!
Find a repair manual for your Gas Mileage Tips.
By Advertisment,
Posted at Sat May 17, 2008 8:01 am
By 2CarPro Ken, Certified ASE Technician
Reputation: 146.7Reputation: 146.7Reputation: 146.7Reputation: 146.7Reputation: 146.7Reputation: 146.7Reputation: 146.7 (147) Give Feedback | Votes: 7
good call on thoses o2 sensors, also if the MAF (mass a air flow) and coolant sensor is out of range it will effect the mileage also. Smile
Posted at Sat May 17, 2008 11:42 am
By rasmataz, Certified 2CarPros Master Technician
Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7Reputation: 743.7 (744) Give Feedback | Votes: 66
The following fuel saving tips can help you save gas and improve fuel economy:
Most Common Fuel Wasters:
Loose or missing gas caps. 17 percent of U.S. vehicles have a loose or missing gas cap. This allows an estimated 147,000,000 gallons of gas per year to evaporate into thin air.
Underinflated tires
Faulty thermostats
Worn spark plugs
Malfunctioning engine controls
Poor wheel alignment
Fuel Saving Tip #1: Low Tires Waste Gas
Underinflated tires and incorrect wheel alignment can lead to conditions which increase rolling resistance. This is like driving with the parking brake not fully released, it can cost a mile or two per gallon on a car that normally delivers 20 miles per gallon. Correct tire inflation pressure is critical for good fuel economy, safety, maximum tire life and proper vehicle handling performance.
Fuel Saving Tip #2:Keep your car in tune:
Keeping up with regular vehicle maintenance can improve gas mileage by an average of 4.1 percent. Results may vary depending on the kind of repair and how well it is performed. Ignition misfires are one of the biggest fuel waters of all!
Fuel Saving Tip #3: Keep Your Air Filter Clean
An air filter clogged with dirt, dust and bugs chokes off the air and creates what is called a "rich" mixture - too much gas being burned for the amount of air, which both wastes gas and causes the engine to lose power. Replacing a clogged air filter can improve gas mileage by as much as 10 percent.
Fuel Saving Tip #4: Change Your Spark Plugs
A vehicle can have either four, six or eight spark plugs, which fire as many as 3 million times every l,000 miles, resulting in a lot of heat, electrical and chemical erosion. A dirty spark plug causes misfiring and that wastes fuel. They need to be replaced regularly.
Fuel Saving Tip #5: Improve Your Driving Habits to Improve Fuel Efficiency:
Avoid quick or 'jackrabbit" starts and stops.
Aggressive driving wastes gas. It can lower your gas mileage by 33 percent on the highway and 5 percent in the city.
Observe the speed limit. Gas mileage decreases rapidly above 60 miles per hour.
Avoid excessive idling. Idling gets 0 miles per gallon. Turn your engine off if you are going to be stopped in traffic for 15 seconds or longer.
Use cruise control because it helps you maintain a constant speed limit.
Use overdrive gears because the engine speed goes down saving gas and reducing engine wear.
Avoid carrying unneeded heavy items in your trunk. An extra 100 pounds in the trunk reduces a typical car's fuel economy by 1-2 percent.
Use air vents to circulate air instead of air conditioning.
Fuel Saving Tip #6: Practice Preventive Maintenance:
Simple preventative maintenance steps that you can do to conserve energy, protect your investment, improve highway safety and benefit the environment include:
Regularly changing your motor oil. Dirty oil can reduce fuel economy up to 1 mile per gallon! To maximize fuel economy, use a 5W-20 or 5W-30 synthetic motor oil.
Keeping your tires properly inflated (32 to 34 psi is about right for most cars)
Taking your vehicle for annual brake inspections (Dragging brakes can waster fuel).
Get your transmission fixed. A slipping automatic transmission can cost you 1 mile per gallon or more. It's the same story if you have a manual transmission with a slipping clutch.
A bad cooling system thermostat that causes your engine to run too cold can reduce fuel economy up to two miles per gallon
Posted at Sat May 17, 2008 12:42 pm
also if the windows are down they create aerodynamic drag costing about 5% more wasted gas more with higher speeds.
Posted at Sat May 17, 2008 1:11 pm
Now we are cooking!.. :-0....Love the gas cap raz!
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
