The Lacrosse does not have a servicable fuel filter. It has a strainer that is located in the tank but there is no maintenance required for the fuel system. Might be a good idea to get your injectors cleaned at about 30,000 miles but other than that you should be set...
Cly
Find a
repair manual for your Buick La Crosse Repair Question.
I have an 05 LaCrosse with 33500 miles 3800 series engine, Can someone please tell me where the fuel filter is located so that I can replace it
Thanks
cleaning the injectors on the lacrosse is not recommended.it is possible to cause damage to the injectors if you use an incompattible solvent.GM has not listed any approved injector cleaner for this,other than "CHEVRON TECHRON FUEL TREATMENT"
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
