Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
Ford escort idle trouble
Posted at Fri Feb 03, 2006 3:56 am |
By
Ash Blewer,
Likes to hang around! |
(15) Give Feedback | Votes: 0 |
Hi there, i posted this subject a while back and still havent managed to rectify the problems i am having , so if any you could help it would be greatly appreciated.
The car will start (after 10 mins battery charging off a slave due to lack of use, the battery has gone flat) whilst the engine is cold its sounds very weak and as if it is about to cut out, which it does after giving it revs, i presume this is once the automatic choke is no longer in action, I have been told this is the idle speed control valve and that this is a common fault, if i replace this part , is it the likely solution? thanks guys |
Find a
car repair manual for your Ford Escort Repair Question.
Posted at Fri Feb 03, 2006 6:21 am |
By
Ash Blewer,
[quote="Ash Blewer"]Hi there, i posted this subject a while back and still havent managed to rectify the problems i am having , so if any you could help it would be greatly appreciated.
The car will start (after 10 mins battery charging off a slave due to lack of use, the battery has gone flat) whilst the engine is cold its sounds very weak and as if it is about to cut out, which it does after giving it revs, i presume this is once the automatic choke is no longer in action, I have been told this is the idle speed control valve and that this is a common fault, if i replace this part , is it the likely solution? The car is a 95 'M' reg, 1.8 ghia, zetec efi engine (multi point) cheers |
Find a
Posted at Fri Feb 03, 2006 7:01 am |
By
chevy350guy,
Has a wrench in each hand! |
(20) Give Feedback | Votes: 0 |
have you tested fuel pressure, fuel flow, spark, condition plugs wires, have yoy cleaned the throttle chamber, anything? |
Find a
Posted at Fri Feb 03, 2006 7:25 am |
By
Ash Blewer,
I have replaced the 'air flow sensor' and all spark plugs. still has the same problem, i even replaced the battery with a new one to eliminate that as a problem |
Find a
Posted at Fri Feb 03, 2006 9:43 am |
By
chevy350guy,
look in to possible problems with the fuel system. id like to know the results before you buy a part you may not need. start with the filter, after that do a fuel pressure test. if every thing in the fuel system checks out ok then look into the valve being the problem. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
