Free Car Repair Advice by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
Engine ticking noise - accelerator
Posted at Sat Oct 24, 2009 5:11 am |
By
timgem67,
Have Donated |
Give Feedback | Votes: 0 |
Engine Performance problem
2002 Toyota Sienna 6 cyl Front Wheel Drive Automatic 91200 miles
My vehicle is making a ticking noise when I push the accelerator. It seems to increase in frequency when I accelerate.
I had replaced the timing belt and AC belt as they were due, thinking this would go away.
THe problem still persists. |
Find a
car repair manual for your Toyota Sienna Repair Question.
Posted at Sun Oct 25, 2009 4:11 am |
By
mathiaso,
Certified 2CarPros Technician |
(268) Give Feedback | Votes: 18 |
hello timgem67
check the oil level. what kind of oil and grade do you have in the vehicle? what color is it?
get back after you checked those. |
Find a
Posted at Sun Oct 25, 2009 10:35 am |
By
timgem67,
Have Donated |
Thanks for your response.
The engine oil is nut brown. I have been running Synthetic blend (Valvoline SAE 5W-30).
It has been using synthetic for the past 2 years, but different varieties (Pennzoil, Walmart brand, etc).
It is about a 1/2 quart low. Anything else I can check? |
Find a
Posted at Sun Oct 25, 2009 11:31 am |
By
mathiaso,
For 1/2 quarter low, oil is going somewhere.../does the enine smoke in the morning?
add oil and see if the noise stops.
if the noise still there ticking...
according to what you said earlier that the ticking noise increase in frequency when you accelerate mean technically that ticking noise occures at the same rate as cranckshaft rotation can be cause by piston slap, lose piston pins,worn connecting rod bearing or worn main bearing.
open the oil filer cap and listen to the opening.
listen at each intake and exhaust manifold runner using a stethoscope. place the stethoscope on the fastener holding the valve cover.
disable one cylinder at the time, let me know if the noise stops.
check everything mentioned and keep me updated |
Find a
Posted at Sun Oct 25, 2009 12:50 pm |
By
timgem67,
Have Donated |
Thanks for the response. I do not see any notice any smoke in the morning.
The other thing I failed to mention, the ticking sound is not noticeable when the engine is in idle mode. The problem only seems noticeable on the highway when I am accelerating.
I will fill the oil level and see if that helps. I will keep you posted as I have more info on the other items. |
Find a
Posted at Sun Oct 25, 2009 1:05 pm |
By
mathiaso,
yes let me know if there i any change. by the way,it could be bearing sound from one of the pulley.
because noise are difficult to describe, rotating pulleys and looking for any wobling sound when belt is remove. that is another possibility. |
Find a
Posted at Tue Oct 27, 2009 5:19 pm |
By
timgem67,
Have Donated |
I filled the oil level in the vehicle, however the sound continues. It seemed to become more faint than previous. |
Find a
Posted at Tue Oct 27, 2009 6:52 pm |
By
mathiaso,
this a mechanic stethoscop. it cost $9.90 at autozone.
Place this stethoscop on the valve cover.
tell me your found.
remove all the spark plugs, squir litle heavy oil in each spark plug hole , then put the spark plugs back
start the engine.
tell me your found.
we are checking the pistons rings and the valve guides. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
