starting at the at the water pump go under the deflection pulley, go over the alternator, down to the power steering pump, around the crankshaft pulley,
around the tensioner pulley, and then back to the pump. pop the cap off the tensioner pulley to access the bolt you will need to turn to install the belt.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins.Click
here to find out more.
