I have a 1993 Buick Roadmaster 120,000 miles with 5.7 engine.My battery was draining overnight with everything off,so I did an engine off all lights etc. off and got a 2.26 amp draw I started pulling fuses one at a time and observed that when I removed the fuse that has CLUST. printed on the fuse box cover (15 amp) I got a normal draw of 0.1 amp draw .I was under the impression the CLUST meant cluster yet when I took the car out at night with that fuse removed the cluster lights and guages still were operating???So what does that fuse CLUST. incorporate in the system? Thanks much.
Find a
repair manual for your Buick Roadmaster Repair Question.
Posted at Tue Mar 27, 2007 11:36 am
By
Advertisment,
Find a
I have been chasing a battery drain. The fused circuit I can find that i find pulling current is pulling 0.110 amps.
You said in you rpost that is normal. I have no idea. But if you are sure then I'll quit chasing my circuit looking for 100 milliamps.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
