Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair & Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Discount Auto Parts
Vehicle Repair Online Repair Manual
Vehicle Repair Car Maintenance
Vehicle Repair Car Safety Information
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Forum Topics
Auto Repair2001 Toyota Sienna Stuck...
Auto Repair94 Pontiac Grand Am 2.3 Q...
Auto Repair2004 Ford Expedition Con...
Auto Repair1997 Other Plymouth Model...
Auto Repair2001 Ford Windstar Shutt...
Auto Repair2003 Mitsubishi Montero
Auto Repair1999 Lincoln Continental ...
Auto Repair1996 Chrysler Town And Co...
Auto Repair1995 Chevy Tahoe O2 Sens...
Auto Repair1986 Other Isuzu Models I...
Auto Repair1999 Volkswagen Jetta Ra...
Auto Repair1998 Dodge Neon Overheating
Auto Repair1991 Other Mercedes Benz ...
Auto Repair1996 Volkswagen Jetta Ai...
Auto Repair2001 Ford Windstar Plugs
Auto RepairMore Forum Topics...
Locate Auto Parts
Latest How-To Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Automotive Repair Forum
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
coolant leak
Posted at Tue Oct 23, 2007 5:05 pm
By wnflygirl, New to the forum
Give Feedback | Votes: 0
Have 1998 3.5 RL V6, 166K miles with a mystery coolant leak. I need to fill the reservoir every week with about 1.5 liters of coolant/water. There are no visible leaks. Repair garage pressure tested coolant system for days and could not find what problem was. Replaced radiator hose and cap and gasket, replaced all hoses. As long as the reservoir is filled the car does not overheat. Tends to use more from the reservoir if I use the a/c. The heater is not a problem, there is no leak under the dash from the heater core. There are no smells, no smoke and car runs like a top. Will a bottle of leak sealant in the radiator fix the problem or do I have a larger problem with the water pump or head gasket. Appreciate the help...
Find a repair manual for your Acura RL Repair Question.
Posted at Tue Oct 23, 2007 10:49 pm
By BMRFIXIT, Tech level 9
Reputation: 283.2Reputation: 283.2Reputation: 283.2Reputation: 283.2Reputation: 283.2Reputation: 283.2Reputation: 283.2Reputation: 283.2Reputation: 283.2Reputation: 283.2Reputation: 283.2Reputation: 283.2Reputation: 283.2Reputation: 283.2 (283) Give Feedback | Votes: 12
did they check the over flow tank and hose
I'm not a big fan of rad seal
you can have the headgasket checked
good luck
Posted at Thu Oct 25, 2007 9:53 am
By Bruce Hunt, Certified 2CarPros Master Technician
Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5 (398) Give Feedback | Votes: 38
I doubt the water pump would be at fault. That would show signs of leaking and get steadily worse fast. I would put my money on a head gasket problem. You could have a leak down test down to find the source of water/coolant disappearing act. The car does not need to be fogging smoke out the back to be using it or attempting to burn the coolant. All fingers are pointing to the head gasket. One word I might offer is to NEVER use radiator stop leak. The junk compounds the problem with blockage in other locations, etc. Bad choice to use that.
Make a small donation! (We will make sure your question will be answered promptly)
Reply to topic
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins.Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
Computer Repair
