Car Repair Talk - Ask a Question, Get a FREE Answer.
Go Back
check engine light - DTC code P1456
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Sat Apr 28, 2007 12:09 pm |
By
mmaddox,
Likes cars! |
(10) Give Feedback | Votes: 0 |
I have a 2000 Honda Odyssey with a 3.5 liter V-Tec engine. The check engine light came on. I used an OBD2 scanner tool and retreived code P1456, which my service manual shows as "EVAP System Leak Detected (Fuel Tank)." I have since replaced the fuel cap, making sure to twist it 3 or 4 clicks, and then erased the code. The check engine light came on during the next couple of trips, and my scanner later showed the same code. What tests would you recommend next in order to isolate the problem? What is the likely culprit?
| Find a
car repair manual for your Honda Odyssey Repair Question. |
Posted at Mon Apr 30, 2007 2:50 pm |
By
mmaddox,
Likes cars! |
| Bruce Hunt wrote: | | When you fill at a station does the nozzle often click off early or prematurely? I suspect a ventilation problem. |
No. The nozzle does not click off early or prematurely when I fill at a station. Any other ideas as to what the problem might be. Thanks
| Find a
Posted at Tue May 01, 2007 4:45 am |
By
Bruce Hunt,
Certified 2CarPros Master Technician |
                    (418) Give Feedback | Votes: 39 |
Try these tips:
Fuel filler cap, vacuum connection, fuel tank, fuel tank pressure sensor, evaporative bypass solenoid, evaporative two way valve, evaporative control canister vent shut valve, evaporative control canister and evaporative purge control solenoid. You have to understand that computer codes rarely define the exact component that has failed. All the computer code tells you is that a system that could have one component or many is not operating within the acceptable parameters of the computer's program. Code P1456 means that your vehicle is failing to contain/hold the gas vapors in the gas tank. Retrieving the code in your case was the easy part. If you're lucky it will be simply a replacement gas cap. If it is more than that, you'll need to have the problem diagnosed. Because of the complexity of the system, it may take a couple of hours and some specialized equipment to diagnose the cause. You'll want to be sure the right part is being replaced because some of the components listed are pricey and you don't want to be replacing them on a guess. It would be great if the computer could make a little red flag pop up from the defective component. But then I would have less gray hair and be out a job if that were the case.
| Find a
Posted at Wed Apr 30, 2008 8:57 am |
By
Crit21,
New to the forum |
It's most likely your gas cap. It's either loose or missing. Our 99 Civic had the same problem. My Passat also had a trouble code for the same thing. When you tighten the cap, you should make it click at least 3 times.
| Find a
Posted at Thu Sep 04, 2008 8:56 pm |
By
Dak,
New to the forum |
My wife's '01 Odyssey threw a CHECK ENGINE light when I was traveling on business. I asked her to take it to the dealer and $105 later the code was translated to her as a loose gas cap. THe dealer cleared the code. Before I got home from my trip, the light came back no. When I returned home, I used some silicone grease to lube the gasket on the fuel cap. After a few days, the light turned off on its own. I just bought an Actron 9180 OBD2 scanner and found the P1456 in the system. I cleared it using the tool.
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
