Audi A3 SE 1998 91000miles - Car idles high and cuts out
Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair & Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Discount Auto Parts
Vehicle Repair Online Repair Manual
Vehicle Repair Car Maintenance
Vehicle Repair Car Safety Information
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Forum Topics
Auto Repair1988 Ford Bronco Will No...
Auto Repair2001 Toyota Sienna Stuck...
Auto Repair94 Pontiac Grand Am 2.3 Q...
Auto Repair2004 Ford Expedition Con...
Auto Repair1997 Other Plymouth Model...
Auto Repair2001 Ford Windstar Shutt...
Auto Repair2003 Mitsubishi Montero
Auto Repair1999 Lincoln Continental ...
Auto Repair1996 Chrysler Town And Co...
Auto Repair1995 Chevy Tahoe O2 Sens...
Auto Repair1986 Other Isuzu Models I...
Auto Repair1999 Volkswagen Jetta Ra...
Auto Repair1998 Dodge Neon Overheating
Auto Repair1991 Other Mercedes Benz ...
Auto Repair1996 Volkswagen Jetta Ai...
Auto RepairMore Forum Topics...
Locate Auto Parts
Latest How-To Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Automotive Repair Forum
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
Goto page 1, 2  Next
Posted at Sun Feb 19, 2006 1:57 pm
By christhedon, New to the forum
(15) Give Feedback | Votes: 0
My symptoms are as follows:
( 1 & 2 happen intermittently)
1) The car idles at 2000 RPM (normally just below 1000RPM)
2) The car cuts out when I stop at say a traffic light and when I try to restart it it doesn't start. It turns over but doesn't seem to rev up. After a few minutes of trying the car fires up (NB I have to pump the gas peddle to get it started. Normally I don't need to do this.)
3) The car once cut out as I was driving at approx. 10 MPH. No matter how hard I pushed the accelarator peddle the car would not accelarator and the rev counter just went down to 0. I then experienced the problem of the car not starting again.
NB (1) happens more often than (2).
Please could you let me know what the problem could be?
Thanks in advance,
Chris
Find a repair manual for your Audi A3 Repair Question.
Posted at Mon Feb 20, 2006 5:50 pm
By peppermrj, Certified 2CarPros Master Technician
Reputation: 100.2Reputation: 100.2Reputation: 100.2Reputation: 100.2Reputation: 100.2 (100) Give Feedback | Votes: 7
Are you getting any codes (Dash lights)?
Could be any number of sensors. Hopefully the codes will help narrow down the high idle.
The stalling could be a dirty fuel filter. Has it ever been changed? It also would explain NB 3.
Good luck and let us know. Smile
Posted at Tue Feb 21, 2006 1:27 pm
Thanks for the reply!
I am not getting any dash codes (none of the warning lights are lighting up).
I am not aware of having a fuel filter replaced.
I took the car to two garages:
Garage 1 said it was the lambda sensor and possibly the air flow meter.
Garage 2 said it was the throttle needed replacing.
I drove 100 miles yesterday and it was fine after. It seems the car is most prone to cutting out when it is just warming up, but that could just be a coincidence so far.
Does that info above help?
Thanks,
Chris
Posted at Tue Feb 21, 2006 4:43 pm
I would try the least expensive options first. Replace the fuel filter, clean the air flow meter, and clean the throttle.
The lambda or O2 sensor has more to do with a fully warmed up engine.
Posted at Wed Feb 22, 2006 1:43 pm
Would these things be done as part of a standard service?
If I get the symptoms while the car is warming up does that mean the lambda and O2 sensors are not at fault?
One of the garages told me that cleaning the throttle would cost £60 however it may cause permanent damage to the car if I drive it afterwards. What is your opinion on that?
Thanks, Chris.
Posted at Sun Feb 26, 2006 4:00 am
Thanks for looking at this. I just have a few other quetsions which may help:
If a computer were hooked up to the car and it was the lambda sensor or airflow meter or throttle or fuel fillter would it pick those up?
Or is this a case of "here are the symptoms and the corresponding diagnosis for this". I.e. There is no possible way of narrowing down without trying something and seeing whether that fixes it?
Or can I provide any more detail on the symptoms which may help home in on the actual problem? I.e. the symptoms when it is lambda sensor is *not exactly* the same as the symptoms when the fuel filter is playing up. In which case what info would you need?
Thanks a lot in advance,
Chris
Posted at Sun Feb 26, 2006 8:02 am
After rereading your post I did not address the 2,000 rpm idle. That can be caused by a vacuum leak. Check all your vacuum lines for proper connection, brittle cracks, and soft and gummy leaks. Look closely at the PVC valve and the power booster for leaks from their hoses and connections. They require a lot of vacuum. Vacuum leaks can also cause the intermittent stalling.
Changing the fuel filter should be a standard service item done at presribed intervals. Difficult to test for a clogged filter short of removing it and measuring the flow rate thru it. It is cheaper to simply replace.
The O2 or lamda sensors is considered a maintenence item that should be replaced around 100,000 miles. It definitely can be tested. Most better OBDII scanners and the dealer test equipment will be able to monitor it's function and determine it's status. The lamda has to reach at least 600F degrees to function properly. This should only takes minutes.
The air flow meter can be tested but the results are normally a "pass or fail". Testing would not indicate if a cleaning would help.
Their is a throttle position sensor on the throttle body that can be tested. Again it is a "pass or fail". The test will not determine if a cleaning will help. Some throttle bodies come with a special coating to prevent buildup. The manufacturer recommends that they not be cleaned. Check your service manual or the manufacturer to be sure. Cleaning would remove the coating and necessitate more cleanings.
A hookup to a computer will monitor the functions of all engine controll devices and be able to pinpoint any that are not operating correctly. There are several not even mentioned that can cause the symptoms you have described. If you find no vacuum leaks and the fuel filter replacement and cleanings don't help then I would have the computer diagnostic done.
Sorry for the long post but hope this helps. Smile Let us know.
Posted at Sun Feb 26, 2006 1:05 pm
Thanks a lot!
I notice that the car seems to have most problems when it is cold/just warming up. Once its warm its not so bad. Recently it has been having the problems more frequently. I've been experiencing more juddering when in low revs in say gear 2/3.
I just wanted to better undestand what a PVC valve is and power booster?
I understand vacuum lines in layman terms are the tubes that connect bits of the car.
PVC could be PCV? Something which stops rubbish in the oil going into the engine?
Power booster?
Thanks again,
Chris
Posted at Sun Feb 26, 2006 1:21 pm
My bad. Embarassed
PCV = positive crankcase ventilation. It uses engine vacuum to perform it's function.
Power booster = brake booster It is a large metal canister that has the brake master cylinder attached to it. It's function is to require less foot pressure on the brake pedal to stop the car. It also uses vacuum to perform it's function.
A vacuum leak is air entering the engine that is not metered. It will normally cause a high idle. It will also confuse the computer as to the proper amount of fuel to add for the engine to run properly.
A good read on the subject of finding vacuum leaks is @ http://www.aa1car.com/library/vacleak.htm
Good l;uck. Question Where are you located?
Posted at Sun Feb 26, 2006 1:35 pm
I'm located in London.
Thanks for the link. Seems fairly easy to understand. One thing I noted "Vacuum siphons fuel through the idle, main metering and power circuits" however I thought vacuum was more to push/pull air around the system?
Goto page 1, 2  Next
Make a small donation! (We will make sure your question will be answered promptly)
Reply to topic
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins.Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
Computer Repair
