Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair & Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Discount Auto Parts
Vehicle Repair Online Repair Manual
Vehicle Repair Car Maintenance
Vehicle Repair Car Safety Information
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Forum Topics
Auto Repair1993 Honda Civic
Auto Repair1997 Vauxhall Astra Brak...
Auto Repair2005 Dodge Neon Check En...
Auto Repair1988 Chevy Cheyenne Firi...
Auto Repair1998 Jeep Cherokee Probl...
Auto Repair2001 Mitsubishi Galant D...
Auto Repair1993 Buick Skylark Stalling
Auto Repair2006 Nissan Altima Indic...
Auto Repair2004 Acura Tl Ac Stopped...
Auto Repair2001 Nissan Pathfinder Re...
Auto Repair1993 Ford Explorer Lights
Auto Repair1990 Geo Storm Timing Belt
Auto Repair2001 Ford Focus Leaky/ba...
Auto Repair1990 Dodge Ram Heater Core
Auto Repair1979 Chevy Van Reverse S...
Auto RepairMore Forum Topics...
Locate Auto Parts
Latest How-To Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Automotive Repair Forum
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
Acura Vigor Flashing Oil Light
Goto page 1, 2  Next
Posted at Wed Sep 12, 2007 10:02 pm
By FlashN, Have Donated
Give Feedback | Votes: 0
1992 Acura Vigor GS, 125000 miles, automatic.
Background:
(1) Oil light was flashing. Had it towed to the shop. Oil level was found fine. Engine was running smooth.
(2) Drove it for another 500 miles. Oil light came on again. Took it in, replaced oil sending unit. Also blew out screen, small debris. No more flashing oil light. Engine still running smooth.
(3) Oil light came on again. Somebody else drove it, timing belt broke.
(4) Had engine torn apart, found camshaft oil-starved, engine ruined.
Questions:
(1) Your best theory?
(2) Should I not have driven the 500 miles before replacing the sending unit? Could that have caused damage that resulted in the broken timing belt?
(3) Could it be that the debris in the screen had been around for a long time, starving the cam?
Find a repair manual for your Acura Vigor Repair Question.
Posted at Wed Sep 12, 2007 10:13 pm
By mhpautos, Certified 2CarPros Master Technician
Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8 (369) Give Feedback | Votes: 11
Hi there,
Hindsight is a wonderful thing isn't it! When the oil light started to indicate did the mechanic do an oil pressure test? If they did maybe they would of found that the oil pressure was far to low, the debris in the strainer may have be part to blame but the real fault is the low oil pressure. The cam being at the end of the line so to speak will suffer first with insufficient oil pressure, there may be a blockage in the gallery so the bottom end is OK, but the top is lacking to the point that it seized. Oil lights are only an indication that something is amiss, better to spend a few dollars to have it checked properly than hope for the best.
Mark (mhpautos)
Posted at Thu Sep 13, 2007 5:50 am
By Bruce Hunt, Certified 2CarPros Master Technician
Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5Reputation: 397.5 (398) Give Feedback | Votes: 38
There are two belts under the timing cover and they both resemble timing belts. One is the timing belt and the other is the one that runs the oil pump. I would venture that it went out and now the head is starved of oil. Is it trully the entire engine that was damaged or was it just the head. I would start there.
Posted at Thu Sep 13, 2007 12:56 pm
Thanks, Mark and Bruce.
Yes, in hindsight, the oil pressure should have been checked. But my mechanic tells me that there would have been other signs - like a rough-running engine - if oil pressure was an issue. So they didn't check it, becuse the engine was really running very smoothly. So they figured the sending unit would need to be replaced, which I got done in step 2.
So - if the sensor is flashing, and the oil level is fine, would you automatically go check the oil pressure next, even if there are no other warning signs e.g. a rough-sounding engine?
Thanks - FlashN
Posted at Thu Sep 13, 2007 2:33 pm
Just the head was damaged.
Posted at Thu Sep 13, 2007 2:58 pm
Hi there,
if the oil pump drive failed the oil pressure would drop to zero and there would be plenty of audible warning that something was wrong. If the pump belt was slipping, this would cause low oil pressure at high load requirements, a faulty oil pressure relief valve can also be at fault. It is not uncommon to see foreign material such as excessive sealants being sucked into the oil strainer causing issues, or just dirty oil with lots of carbon deposits floating around getting lodged in galleries and causing fatal blockages, we mere mortals can suffer from the same problem. So there are many reasons why this disaster occurred , but for my money flashing oil lights are a cause for real concern. A full post mortem will reveal all.
Mark (mhpautos)
Posted at Sun Oct 07, 2007 10:37 am
By duckboy88201, New to the forum
ok i took my car to the mechanic to get my water pump replaced and when i got it back the chyeck engine light was on and i asked him about it and he didnt know what to say so he said if something major happens to come see him, second my car was ideling at about 3,000 rpms and he said he didnt touch the idle control and he adjusted it anyeways but then when i left and went home my car started jumping idle some people car it honda virus cause the engine would go up to about 2,000 rpms and drop to 1,000 rpms and go back in forth until i took off but now the battery loight keeps flashing on and ofgf sometimes and i dont know what to do now the battery is only a few months old and plus my oil light keeps flashing and i dont know what to do so if you can help me out i would really appreciate it very much thank you
Posted at Tue Oct 09, 2007 5:07 am
Your mechanic is not too much of a mechanic. Did he only replace the water pump or did he do the timing belt? The water pump being done would indicate that the coolant was low. Did it get filled back to capacity? Did the cooling system get purged of air? The air in the system or low coolant can cause some of the problems you are experiencing. The oil light flashing might be an indicator that the belt to the oil pump was installed wrong or is broken. I would consider having the oil pressure checked. My recommendation is not to return to this mechanic unless you have left out a lot of what transpired.
Posted at Fri Oct 12, 2007 4:17 pm
yea he did replace the timing belt but i dont know if he purged the air from the system but the only time the oil light flashed is when my tach goes off for a little while and comes back on i dont know how to stop my tach from going off and comming back on if u can help with that then i would really appreciate it thanks for the other info though
Posted at Mon Oct 15, 2007 3:26 pm
Quite frankly your problem could be VSS (variable speed sensor) or it could be a short in the dash wiring to the tach ie loose connection, etc.
Goto page 1, 2  Next
Make a small donation! (We will make sure your question will be answered promptly)
Reply to topic
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins.Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
Computer Repair
