Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2002 Ford Ranger Four W...
Auto Repair1986 Pontiac Firebird C...
Auto Repair1997 Ford Ranger Fuses ...
Auto Repair2001 Honda Crv
Auto Repair1994 Ford Ranger Blower...
Auto Repair2003 Dodge Dakota Heat ...
Auto Repair1994 Ford Ranger Wiper ...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
97 Civic Power Door Locks not functioning
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Goto page 1, 2  Next
Posted at Fri Jul 27, 2007 12:43 pm
By nicklunn44, Likes cars!
Give Feedback | Votes: 0
1997 Honda Civic LX 4dr
200,000 miles
The power door locks on my car are not locking/unlocking the doors. None of the doors. I checked the fuses and they are ok. I also tested the switch and it showed continuity for both lock/unlock. I then reconnected the wires and tested them at the other end, where it plugs in to the Power Lock Control module and flipped the switch again. Continuity appeared on the wires there. That eliminated a bad wire from the switch to the module.
I then, referencing the wiring diagram in the Haynes manual, tested continuity from the control module to the driver's door lock actuator. This seemed strange to me, but the wires which were supposed to (if I read the diagram correctly) indicate the switch locking/unlocking showed continuity without doing anything to the switch.
With everything plugged in, toggling the switch does not result in any sound being made (the typical clicking sound that occurred when i would lock or unlock the doors)
My questions are:
1) how often does the power lock control module fail?
2) how can i remove the actuator to more easily test it?
3) does the lack of that sound indicate actuator or this control module?
4) would a failing driver's door actuator cause the other doors to not lock/unlock, or are most likely all 4 door hosed up?
Let me know if you need anymore info or more explanation. I'm also attaching a pic of the control module from one i found on eBay.
Thanks,
Nick
Find a car repair manual for your Honda Civic Repair Question.
Posted at Fri Jul 27, 2007 1:03 pm
By Bruce Hunt, Certified 2CarPros Master Technician
Reputation: 417.7Reputation: 417.7Reputation: 417.7Reputation: 417.7Reputation: 417.7Reputation: 417.7Reputation: 417.7Reputation: 417.7Reputation: 417.7Reputation: 417.7Reputation: 417.7Reputation: 417.7Reputation: 417.7Reputation: 417.7Reputation: 417.7Reputation: 417.7Reputation: 417.7Reputation: 417.7Reputation: 417.7Reputation: 417.7Reputation: 417.7 (418) Give Feedback | Votes: 39
I am headed out the door but I quick pulled together material that should help you out with diagrams, testing, etc. I will email it to you here shortly.
Posted at Fri Oct 26, 2007 12:19 pm
By airday, New to the forum
How did you determine the problem and what did you do to fix it. My civic has the same issue.
1997 Honda Civic LX 4 Door
118,000 miles
Posted at Sat Oct 27, 2007 11:12 am
By Tudor, New to the forum
hey i have the same problem except i have a 1999 honda civic ex, i cant figure out what the problem is but my locks stil lmake the clicking sound. anyone know what could be the problem??
Posted at Sun Nov 25, 2007 7:48 pm
By luism, New to the forum
Is it that the lifespan of the part is 10 years?
Can I see those diagrams too?
What parts would I need to order?
Thanks for any help Smile
Can anyone recoomend a reputable (fair priced) honda mechanic in the area? Chicago?
Thanks
-Luis Confused
Posted at Thu Jan 10, 2008 7:39 am
By pilotstev, New to the forum
Has anyone fixed the problem? I have a 1998 Civic EX coupe with exact same problem. Question: If you replace the lock control module, do you need new remotes for the car? Can anyone please e-mail me the solution. Razz
Thanks. Laughing
Posted at Thu Jan 10, 2008 10:49 am
By topgun1226, Likes cars!
(10) Give Feedback | Votes: 0
The remotes can be reprogrammed at any time, I've bought a few off eBay. There's a way to associate them with your specific keyless...
http://www.handa-accessories.com/crv/KEYLESSPROG.pdf
Great resource.
Posted at Sun Jan 13, 2008 1:41 pm
Thanks a lot for the info on the keyless info. I still have yet to determine the solution to my inoperative power locks. I get no clicking sound at all with remote or with electric switch on door. I have checked the fuses. Honda wants $100 for a new Power Lock Module (the blue box in the picture). Will replacing that fix my problem... what easy troubleshoot items am I missing? What is the common malfunction with Hondas in this situation? I am fairly confident it is not the locking mechanism at the door locks themselves, but not 100%.
Please help if you can. I've had this car for 10 years, and want to repair everything before I sell it.
Thanks.
Posted at Fri Feb 01, 2008 1:58 am
By shing_email@yahoo.co.uk, New to the forum
I have the central locking problem in my 2003 civic. It only works when the engine/power is on. It happened since my son dropped a coin into the CD player. It stopped working since then, besides central locking, auto light fails when the engine/power is off, as well. All fuses are OK. Any suggestion ? (I haven't changed the dead CD player, btw). Thanks for your help in advanced.
Posted at Sat Mar 08, 2008 9:37 pm
By motoi860, New to the forum
hi, im having the same problem.. can anyone pls pm me how to fix this.. i would appreciate i...thanks
Goto page 1, 2  Next
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
