Logo Automobile Information Add Site to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair Car Repair Manuals
Auto Repair How Does it Work
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Automobile Safety Inspection
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Table
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Auto Repair Auto Parts
Search Website
Recent Repair Topics
Auto Repair2002 Toyota Camry I Had...
Auto Repair2003 Ford Explorer "flo...
Auto Repair1999 Ford F150
Auto Repair2005 Buick Century Sque...
Auto Repair1998 Subaru Legacy Won'...
Auto Repair2004 Ford F250 Fuel Filter
Auto Repair2004 Honda Crv Emissions
Auto Repair More Repair Topics...
Free Auto Repair Advice by Professional Mechanics
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2003 ford windstar abs c1185 trouble code
Goto page 1, 2, 3 ... 51, 52, 53  Next
Posted at Mon Jul 23, 2007 6:47 pm
By frenchbull, Likes to hang around!
Give Feedback | Votes: 0
I had the front pads replaced and rotors resurfaced and rear brakes serviced. And at the same time the ABS and red brake warning light came on. The mechanic was dumbfounded said he didn't do anything to make that problem occurr. He changed the pads and the problem seemed corrected. Approx. 200 miles later. the brakes were applied hard ,and soon after, the lights came back on intermittently. Seems like the lights come on quickly when the car is hot and been driven a while. If the car is cold or has sat overnight, the lights don't come on. Took it to the dealer, they ran a diagnostic ($100) said it needed a new ECU ($700). Don't mind paying if that's what it really needs, but it just seems like the problem occurred when the pads were replaced and maybe the original mechanic bent or tore something. The dealer is adamant that the C1185 code would not be affected by anything the original mechanic did (replacing the front brakes, resurfacing the rotors and rear brake service). I feel backed into a corner. Your thoughts.
Find a car repair manual for your Ford Windstar Repair Question.
Posted at Tue Jul 24, 2007 4:42 am
By justanold, Should apply to be a 2carpros tech! :)
Give Feedback | Votes: 22
HELLO! Need some clarification and info. you state several times that the "lights" come on. would that be the RED brake light and the orange ABS light? miles? what is a rear brake service? did they just check the rear brakes? you said the mechanic replaced the pads twice. is this correct? good answers to all will receive the same in return. i think you've been had. Cool Cool Cool
Posted at Wed Jul 25, 2007 1:14 pm
Both the ABS(Yellow) & Brake(Red) Lights come on. Rear Brakes were cleaned by using a solvent, not sure what it was. Then they were rinsed with water & air dried. This was all done with a high pressure hose. Then the rear brakes were adjusted. Front pads were replaced after 1 mile of driving, the lights turned on & the van was returned to the repair shop. Everything was rechecked & the tech was not sure about what was happening. Advised me to drive van for a few days to break in the pads. The light went back on, I returned back to the repair shop & he ran a scan & it showed the above code(C1185). He agian was unsure, so he replaced pads again. The light continues to come on & off. So I took the van to the dealer where I was told that I needed to replace the ECU which I mentioned in the prior message. The van currently has 36K & this was the first set of replacement pad & rear adjust done. Do you have any advise?
Posted at Wed Jul 25, 2007 4:44 pm
HELLO! One quick verification test. with the light out..slowly accellerate to 25 MPH. light didn't come on. now repeat from a stop..accellerate hard to 25 MPH or more. light came on. get back with results. i'll be here for a few hours. Cool Cool Cool
Posted at Thu Jul 26, 2007 6:14 pm
By dhtuttle, Likes to hang around!
What's the status? I have the same exact problem with my Windstar in addition to the HCU. Is it necessary to replace those or is there an easy fix? Question
Posted at Thu Jul 26, 2007 8:39 pm
HELLO! I haven't heard back yet. tell me what your symptoms and codes are. have you tried the verification test yet? what have you been told? when did it start? do both lights come on? let me know. Cool Cool Cool
Posted at Fri Jul 27, 2007 9:23 am
The problem started approx. 4 weeks ago. Both the ABS and the Brake Light come on immediately when the vehicle is warm. Sometimes they won't come on at all when the vehicle is cold. I brought to a Ford Dealer and they hooked up their computer and diagnosed that the ECU and HCU need replacement. At first I tried cleaning the rear brakes and adjusting them. No luck. I did a visual inspection on the ABS sensors and they appeared in good shape. I'm stumped?! Confused
Posted at Fri Jul 27, 2007 4:00 pm
Sorry I didn't reply right away. (work issues) I drove the van as you suggested (slowly accelerating to 25 mph and hard acceleration to 25 mph or more). The lights did not come on. However my wife drove the van in the rain and went through a few water puddles and the lights came on. So the acceleration test did not cause the lights to come on but going through water puddles did. So now, the lights come on: 1. if the car has been driven a long time. Restarted and driven again without a chance to cooldown. 2. Driven through some water puddles.
Posted at Fri Jul 27, 2007 4:05 pm
Sorry I didn't reply right away. (work issues) I drove the van as you suggested (slowly accelerating to 25 mph and hard acceleration to 25 mph or more). The lights did not come on. However my wife drove the van in the rain and went through a few water puddles and the lights came on. So the acceleration test did not cause the lights to come on but going through water puddles did. So now, the lights come on: 1. if the car has been driven a long time. Restarted and driven again without a chance to cooldown. 2. Driven through some water puddles. Any help appreciated. Thanks.
Posted at Sat Jul 28, 2007 12:32 am
By j4racin, Likes to hang around!
Hi, my name is Jeff from Charlotte, NC (Nascar capital) and I'm a first time user. I just happened to cross this thread and joined so that I could give you my .02 cents. I have a 2003 Windstar SE Sport with the same exact problem. I have been trying to figure this out for quite a while now. I have not been able to figure out if its heat or speed that triggers the lights to illuminate. It's always both yellow (ABS) and red (e-brake) lights. The problem is sort of intermitent. I have changed the front pads and inspected all the sensors visually and wiped the sensors clean with a mild detergent. A co-worker and I went to the dealership together and bought the same vans (mine green, his silver). He has not had this problem. I have already replaced the alternator and his is fine. Mine has less mileage and stays in the garage. His stays outside and is neglected, yet, he has had no service repairs since the purchase. I believe the vehicles were assembled in Canada. The bottom line is we all share the same problem. I am sure there are many many more out there too. We need to figure out what is causing these lights to illuminate. Lets all stick with this thread until we resolve this issue. My brakes are good, new pads and brake lines bled. The master cylinder fluid level is full. There are no leaks anywhere. Ah, just thought of something. Does anyones brake pedal make a creeking (scrunching) noise when depressed. Mine does and it has nothing to do with the pedel forward adjustment. Does anybody elses brake pedal make scrunchy noises when pumped? Maybe it's a clue. Lets keep thinking and updating. It's 4:30am and I need some sleep. I shall check back later on. Good night.
Jeff
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Computer Repair Question l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
