Free Auto Repair Advice by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2008 Toyota Sienna trouble codes
Posted at Fri Nov 13, 2009 5:56 am |
By
mike patrick,
Have Donated |
Give Feedback | Votes: 0 |
Engine Performance problem
2008 Toyota Sienna 6 cyl Two Wheel Drive Automatic 30000 miles
my sienna started but idled very rough then died and would'nt start,after 10 min it started ran fine.I buoght a code reader and got p0031,poo51,po351thrup0356 my reader tells me these are problems whith the heater control and ignition coil. its been 2 days since the problem and is running fine ,are these problems that need to be looked into. thank you |
Find a
car repair manual for your Toyota Sienna Repair Question.
Posted at Fri Nov 13, 2009 10:39 am |
By
KHLow2008,
Certified 2CarPros Technician |
         (5182) Give Feedback | Votes: 69 |
Hi mike patrick,
Thank you for the donation.
When problems are intermittent, it is difficult to diagnose the problem. since problem has not recurred, there is a possibility the cause was a loose connection somewhere and might not occur again untill much later.
The only thing that you can and need to check for would be connections of wire harness and the ignition coils. Other than that, you would have to wait for the problem to occur to get into diagnostics. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
