Hi JDPRIL20,
Thank you for the donation.
You need to remove the taillamp assy to replace the bulbs.
TAIL LAMP REPLACEMENT
Preliminary Procedure: Open the rear compartment lid in order to access the tail lamp screws.
1 Tail Lamp Assembly Screws (Qty: 2) Tighten: 2.5 N.m (22 lb in)
2 Chassis Electrical Connector
Tip: Lift the tail lamp in order to disengage the retainer clips then disconnect the electrical connector.
3 Tail Lamp Assembly
Tip: Transfer the bulb into the new tail lamp.
4 Quarter Filler Panel Nuts (Qty: 2)
Tip: Ensure the quarter filler panel nuts are not damaged. Replace if damaged.
TAIL LAMP BULB REPLACEMENT
1 Stop, Tail and Turn Signal Bulb Socket Harness
2 Stop, Tail and Turn Signal Bulb
Tip: Pull the bulb straight from the socket in order to remove.
3 Stop, Tail and Turn Signal Bulb Socket Harness
4 Stop, Tail and Turn Signal Bulb
5 Rear Side Marker Lamp Bulb Harness
6 Rear Side Marker Lamp Bulb
Page 1 of 1 LIGHTING -2007 Saturn Sky 9/7/2008
http://www.ondemand5.com/mric/common/asp/printart.aspx
