Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 12,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2007 Land Rover Discovery 3 Noise when not braking
Posted at Sun Apr 12, 2009 8:12 pm |
By
Hous6795,
New 2Carpros Member |
Give Feedback | Votes: 0 |
Brakes problem
2007 Land Rover Discovery 3 V8 All Wheel Drive Automatic 40000 miles
I just had new brake pads put on my Land Rover LR3. The car has 40,000 miles. The old pads had about 2mm left, so I wasn't metal-on-metal going into the shop. I had EBC brake pads put on. Now, when I am not braking, the rear driver's side wheel has a squeeking sound. It's high pitched, rotational, and only happens at low speeds. Any ideas? Thank you. |
| Find out more about your Land Rover Discovery 3 Repair Question: NEED MORE
TECHNICAL INFO? Car Repair
Manual - Questions by Topic -
First Things to Check - How to Car Repair - How Does it Work?
- Donate Here |
Posted at Thu Apr 16, 2009 2:45 pm |
By
ROVERTECHGOLD,
IT IS POSSIBLE THAT THE NOISE YOU ARE HEARING IS COMING FROM THE PARKING BRAKE. LR3S ARE KNOWN FOR THE PARKING BRAKE SHOES GETTING CAKED IN BRAKE DUST AND SQUEAKING. ALSO, IT IS POSSIBLE THAT ONE OF THE CLIPS THAT HOLDS THE BRAKE SHOES IN PLACE HAS BROKEN. THE REAR ROTORS MUST BE REMOVED IN ORDER TO INSPECT THE PARKING BRAKE. |
- Donate Here |
Make a small donation! (We will make
sure your question will be answered promptly)
