2006 Vauxhall Monaro engine swap problem help please
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Computer problem
2006 Vauxhall Monaro V8 Two Wheel Drive Automatic
Hi . i have swapped my 1990 camaro engine/transmission with a 2006 vauxhell monaro engine/transmission i took the whole thing from a crashed monaro .now the problem that is the engine starts just for one or tow second and stops and the security icon is on .please help since 2006 l have tried tens of electricians and non of them solved the problem . now i'm determined to do it my self with some help from you guys .
did you swap the ECU as well, check this and do a scan, you may have to re program the security system. the ecu may not recognize the key you are using.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
