Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Smells problem
2006 Toyota Sienna 6 cyl Front Wheel Drive Automatic
I was told during service at Toyato that I needed a new "cabin air filter". Where is it located on the above vehicle? I think I can do it cheaper than the dealer.
Behind glove box
open glove box and slide off damper from side box door
push each side of glove box to disconnect the claws
allow glove box to hang down
remove the filter case
remove filter
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
