Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair Car Repair Manuals
Auto Repair How Does it Work
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Automobile Safety Inspection
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Table
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1988 Chevy Truck Runnin...
Auto Repair1996 Geo Prizm Get Noth...
Auto Repair2000 Ford Explorer Noise
Auto Repair2002 Chevy Impala Wont ...
Auto Repair1997 Lexus Gs 300
Auto Repair1995 Pontiac Grand Prix ...
Auto Repair1991 Eagle Summit Front...
Auto Repair More Repair Topics...
Auto Repair Forum - Ask a Question, Get a Free Answer
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2006 Scion tC vacuum leak large
Posted at Sat Jul 04, 2009 3:23 pm
By jdursteler, New to the forum
Give Feedback | Votes: 0
Engine Performance problem
2006 Scion tC 4 cyl Front Wheel Drive Automatic 67,000 miles
So my check engine light came on for the first time yesterday and I took it in to autozone to be diagnosed and they said it has a vacuum leak large? I'm not sure what that is or how to repair it? Anyone have suggestions? And what's an easy way to find the leak? I don't want to take it in because they said it would cost $300 at jiffy lube.
Find a car repair manual for your Scion tC Repair Question.
Posted at Sat Jul 04, 2009 5:05 pm
By rasmataz, Certified 2CarPros Master Technician
Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6 (8489) Give Feedback | Votes: 230
what's an easy way to find the leak? You can try below
ENGINE VACUUM LEAK DETECTION
Okay, now that we have covered what a vacuum leaks do, how do you find components that leak vacuum? One way is to visually inspect all the vacuum hoses and connections. Look for disconnected, loose or cracked hoses, broken fittings, etc. Hey, you might get lucky and find the problem in a few minutes, or you might waste half the day trying to find the mysterious leak. Vacuum leaks are often the elusive needle in a haystack. And if it is not a hose leaking vacuum but something else such as a gasket, worn throttle shaft, injector O-rings, etc., you may never find it using this technique.
A faster technique for finding intake manifold vacuum leaks is to get a bottle of propane and attach a length of rubber hose to the gas valve. Open the valve so you have a steady flow of gas. Then hold the hose near suspected leak points while the engine is idling. If there is a leak, propane will be siphoned in through the leak. The resulting "correction" in the engine's air/fuel ratio should cause a noticeable change in idle speed and/or smoothness (Note: on engines with computerized idle speed control, disconnect the idle speed control motor first).
Aerosol carburetor cleaner can also be used the same way. CAUTION: Solvent is extremely flammable, so do not smoke or use it if there are any sparks in the vicinity (arcing plug wires, for example). Spray the solvent on suspected leak points while the engine is idling. If there is a leak, the solvent will be drawn into the engine and have the same effect as the propane. The idle speed will suddenly change and smooth out.
TIP: If you have a scan tool, look at the Short Term Fuel Trim (STFT) value while you are using carb cleaner or propane to check suspected vacuum leak points. If there is a leak and some of the cleaner or propane is sucked in through the leak, you will see a momentary drop in the STFT reading. This confirms you have found a leak (keep checking because there may be multiple leaks!).
USING SMOKE TO FIND ENGINE VACUUM LEAKS
A much safer technique is to use a smoke machine. These machines feed artificial smoke into the intake manifold, The smoke may also be mixed with an ultraviolet dye to make leaks easier to see. You then look for smoke seeping out of hoses, gaskets or cracks in the manifold and/or use a UV light to find the leak. This type of equipment is often needed to find small air leaks in the EVAP (evaporative emissions) control system. Smoke machines can cost $600 to $2000 or more depending on the model and features, so they are primarily for use by professional technicians.
FINDING LEAKS WITH AN EXHAUST ANALYZER
Propane can also be used in conjunction with an exhaust analyzer (do NOT use carburetor cleaner or you may damage your analyzer!). Engine vacuum leaks almost always cause fluctuating HC readings, so an infrared exhaust analyzer can (1) tell you if there is indeed a leak, and (2) where the leak is using the propane procedure.
Two types of vacuum leaks can be diagnosed with an analyzer. The first kind is a general vacuum leak (PCV hose, brake booster, etc.) that leans out the mixture and causes a very low CO reading and only a slightly higher fluctuating HC reading. The O2 reading will also be high. The second kind of vacuum leak is a "point" leak that affects only one or two cylinders (a leaky manifold gasket or a crack or porosity leak in one of the manifold runners). This will be indicated by a normal or low CO reading combined with high fluctuating HC readings. O2 will again be high.
To find a leak, feed propane at suspected leak points until you note an improvement in idle quality and/or a change in the HC/CO/O2 readings. When you have found the leak, the idle should smooth out, HC and O2 should drop and CO rise.
It is important to note that an overly lean idle mixture will also cause a fluctuating HC reading the same as a vacuum leak. To tell one from the other, there is a simple "trick" you can use. Momentarily enrich the idle mixture to 1.5 to 2.0% CO by placing a clean shop rag over the top of the carburetor. If the engine smooths out and HC drops and remains stable, the problem is a lean idle mixture adjustment. If HC still fluctuates, however, the engine is still too lean in one or more cylinders indicating a vacuum leak.
ELECTRONIC VACUUM LEAK DETECTION
If you like gadgets, there are electronic tools designed to detect vacuum leaks. An electronic vacuum leak detector will beep or flash when it detects ultrasonic vibrations that are characteristic of a vacuum leak. These tools use a sensitive microphone to listen for certain noise frequencies. Though extremely sensitive, these tools sometimes react to tiny leaks that are not really causing a problem, or "false" leaks such as the noise created by arcing inside the distributor cap or normal bearing noise in the alternator.
PRESSURE VACUUM LEAK DETECTION TECHNIQUES
Another way to find an elusive vacuum leak is to pressurize the intake manifold with about three lbs. of regulated air. This can be done by attaching a regulator to your shop air hose, then attaching the hose to a vacuum fitting or the PCV valve fitting on the intake manifold, carburetor or throttle body. Do not apply too much pressure or you may create new leaks! With the engine off and air flowing into the manifold, spray soapy water on suspected leaks. If you see bubbles, you have found the leak.
You can also use the opposite technique, which is to apply vacuum with a hand-pump to various vacuum hoses and circuits to see if they hold vacuum. But this technique means tracing the entire circuit to see where it ends, and disconnecting and plugging any parts of the circuit that do not "dead end" against a diaphragm or valve.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Home l Help l Privacy Policy l User Agreement l About Us l Computer Repair Question l Contact Us l Link to Us l We're Hiring l Affiliate Program
  Copyright © 1999 - 2009 2CarPros.com - Professional Mechanics Online
