Auto Repair Help by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2006 Pontiac G6 how to change brake pads on the front and r
Posted at Sat Jan 31, 2009 5:35 pm |
By
labell,
New to the forum |
Give Feedback | Votes: 0 |
Brakes problem
2006 Pontiac G6 6 cyl Front Wheel Drive Automatic
how to change brake pads on the front and rear |
Find a
car repair manual for your Pontiac G6 Repair Question.
Posted at Sat Jan 31, 2009 5:53 pm |
By
bluelightnin6,
Certified 2CarPros Technician |
             (6788) Give Feedback | Votes: 231 |
REMOVAL FOR FRONT:
Inspect fluid level in brake master cylinder resevoir.
If brake fluid level is midway between maximum-full point and minimum allowable level, no brake fluid needs to be removed from resevoir before proceeding.
If brake fluid level is higher than midway between max.-full point and min. allowable level, remove brake fluid to the midway point before proceeding.
Rais and support vehicle.
Remove wheel.
Install and firmly hand tighten 2 wheel nuts to opposite wheel studs in order to retain the rotor to the hub.
Remove the brake caliper lower guide pin bolt.
Push disc brake caliper pistion into caliper bore using an old inner disc brake pad and a disc brake piston installation tool.
Without disconnecting hydraulic brake flexible hose, pivot the caliper upward and secure the caliper with heavy mechanics wire or equivalent. Remove brake pads from caliper mounting bracket.
Remove brake pad retainers from caliper bracket.
Thoroughly clean brake pad hardware mating surfaces of the caliper bracket, of any debris and corrosion.
Inspect brake caliper guide pins and guide pin boots for damage.
INSTALLATION FOR FRONT:
Ensure brake pad hardware mating surfaces are clean.
Install brake pad retainers to brake caliper bracket.
Install brake pades to caliper bracket.
Remove support and rotate brake caliper into position over disc brake pads and to caliper mounting bracket.
Install lower brake caliper guide pin bolt. (Tighten bolt to 26 lb ft. [ 35 Nm] ).
Remove wheel nuts retaining the brake rotor to hub.
Install wheel.
Lower vehicle.
With engine off, gradually apply brake pedal approximately 2/3 of its travel distance.
Slowly release brake pedal.
Wait 15 seconds, then gradually apply brake pedal approx. 2/3 travel distance again until a firm pedal apply is obtained.
Fill master cylinder auxiliary resevoir to the proper level.
Burnish pads/rotors by selecting a smooth road with little to no traffic. Then accelerate vehicle to 30 MPH (48 KM/H). Using moderate to firm pressure, apply brakes to bring vehicle to stop. Do NOT allow brakes to lock. Repeat burnishing steps until approx. 20 stops have been completed. Allow sufficient cooling periods betewen stops in order to properly burnish the pads and rotors.
Is your vehicle equipped with brake drums or brake rotors on the rear?
Thanks for using 2CarPros.com! |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
